Old 07-01-2014, 08:24 PM   #1
2006 30' Classic
Milton , Florida
Dexter Brake Pads
I have a 2006 model year 30 foot Classic with Dexter hydraulic brakes. I am trying to locate a part number for the brake pads. I have queried Airstream, but have not yet received an answer. Does anyone have a Dexter part number for the pads? Do I go to Dexter for the pads, or can they be located elsewhere?
Many thanks,
F. A. Meloy
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 07-03-2014, 07:54 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I think I have the part number for mine at home. But I also used the Dexter website to research and found all component part numbers on it.
Curious as to what triggered replacement ? All wheels or one or two?
Highly suggest inspecting caliper piston seals for damage or cuts.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-03-2014, 08:11 AM   #3
dznf0g's Avatar
Oswego , Illinois
See if your ID label is still on the axle tube. I would give you my info, but I hesitate to ASSUME that the axles and brakes are the same. They probably are....but.... I would take the axle info to a Dexter Distributor as I have always found them to be more knowledgeable and cheaper than elsewhere. Get ready....these pads are considerably more expensive than auto pads. IIRC they are $250 - $300 per set of four.
-Rich-
Old 07-04-2014, 07:06 PM   #4
2006 30' Classic
Milton , Florida
Pad Replacement
Gary
We are currently on an extended trip. I took the opportunity to crawl under the trailer while we were parked on a paved pad to check the brake pads. There is plenty of pad to finish out this trip, but I want to replace all of the pads prior to our next long trip, so I am trying to locate the part number so that I can order in early August when we return home.
Nick
F. A. Meloy
2006 30' Classic
Old 07-04-2014, 07:11 PM   #5
2006 30' Classic
Milton , Florida
Axle Label
Originally Posted by dznf0g View Post
...See if your ID label is still on the axle tube...
I have sent the axle tube label information to both Airstream and Dexter with a request for the Dexter part number for the brake pads. I am currently awaiting a reply. I am not in a time crunch, and it is a major holiday weekend.
Nick
F. A. Meloy
2006 30' Classic
Old 07-04-2014, 07:45 PM   #6
1974 Argosy 20
Kooskia , Idaho
I just made a post on the service manual for Dexter axles. The information you seek may be in that document.
http://www.dexteraxle.com/i/u/614960...ice_Manual.pdf
Old 07-04-2014, 08:24 PM   #7
dznf0g's Avatar
Oswego , Illinois
I have part# K71-629-00 for my axle....but double check per your label. You need quantity of 2 for that part#.
Here's my label:
-Rich-
Old 07-11-2014, 05:10 PM   #8
2006 30' Classic
Milton , Florida
Dexter Brake Pad Report
Many thanks,
F. A. Meloy
Andy's part number is 86625.
Dexter's part number is K71-629-00.
Airstream's part number is 684008.
These numbers will get enough pads to do one axel and will cost around $200 (+/-) per axel..
Thanks to all that replied.
F. A. Meloy
2006 30' Classic
Old 10-04-2014, 02:48 PM   #9
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
My '08 30' Classic S/O also uses the K71-629-00 pads, and K71-631-00 rotor.
I'm finding discussions where folks are using 'Kodiak' replacement parts.
Is this legit? These Dexter parts are $$$$
($168 for a pair of pads!)
boondockdad is offline   Reply With Quote
Old 10-12-2014, 05:48 PM   #10
Dearborn , Michigan
Images: 21
Found a set of pads here for $119 shipped.
Something curious about brake pad wear on my trailer; the rear axle pads wear much faster... unlike my truck, where the front axle pads wear faster.
Has that been the experience of other tandem axle owners?
Disc brake parts, pads and calipers Excella CM Brakes & Brake Controllers 31 04-16-2011 08:37 PM
brake pads/shoes Maya Brakes & Brake Controllers 5 12-01-2005 07:11 PM
Cracked Brake Pads DavidsonOverlander Brakes & Brake Controllers 6 10-31-2005 09:57 AM
Tow Vehicle Brake Pads? y5e06 Tow Vehicles 5 08-12-2004 12:21 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
