Old 11-19-2018, 05:04 PM   #1
Wadestearns's Avatar
2013 25' International
Palm Springs , California
Dexter Brake Drums Needed STRANDED
Thanks in advance for your help!
I live in the Los Angeles Orange County area, one of the most populous areas in our country.
No Dexter break parts available anywhere??
Need the following parts ASAP:
Qty 2 - part number #023-458-00 - left side backing plates
Qty 2- part number #023-459-00 - right side backing plates
Qty 4- part number #008-388-80 - drums w/bearings never lube
Wadestearns is offline   Reply With Quote
Old 11-19-2018, 05:17 PM   #2
2016 22' Sport
Clinton , Montana
Order on line it would be faster!
Rpatrick16 is offline   Reply With Quote
Old 11-19-2018, 05:21 PM   #3
2007 22' International CCD
Wadestearns,
I suspect pretty much any trailer part supplier would work. Try eTrailer.com online, or "InlandRV" in Corona area. Or the local Airstream dealers.
Remember Google is your friend...
Old 11-19-2018, 06:45 PM   #4
Originally Posted by rmkrum View Post
Wadestearns,
You are totally correct
Why can I find the parts that are needed online shipped via my preference.
I am in the most populated area of the US with over 5 Airstream dealers in the area. They said they could not find any of the break parts that I needed. I have a 2013????
This is a bad mark for Airstream service. I do not like it.
Old 11-19-2018, 07:07 PM   #5
Kevin245's Avatar
I wouldnít throw Airstream under the bus on this. These are common parts not proprietary to Airstream. With the strength of the online economy many brick and mortar businesses simply do not stock much inventory. Iíve had great success with etrailer .
Eleanor Roosevelt
Old 11-19-2018, 07:11 PM   #6
2002 19' Bambi
Lafayette , California
Airstream is not responsible for their dealers not having the parts. That said, the Dexter website shows about 6 Dexter dealers in the LA area. A bit of time on the telephone might find the parts near you. Those dealers should also be able to order the parts.
Tim
Tim A. is offline   Reply With Quote
Old 11-19-2018, 07:17 PM   #7
Vintage Only
1966 26' Overlander
1981 31' Excella Limited
1964 22' Safari
Ramona , California
I had great success with a major wheel and break failure on the road with (and dont laugh) Redneck Trailer Supply. They have 20 US locations and will sell you the entire assemblies cheaper than the individual parts. Here is the one in LA area 11171 Venture Dr, Mira Loma, CA 91752
1966 Overlander, 1981 Excella II, 1964 Safari (for sale)
kenfconnor is offline   Reply With Quote
Old 11-19-2018, 07:18 PM   #8
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I order from Etrailer.com always have Dexter parts in stock and ship same day as order placed with tracking.
Old 11-19-2018, 07:52 PM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
What no private name trailer parts supply houses there? Look at truck supply houses...
Old 11-19-2018, 08:39 PM   #10
2013 20' Flying Cloud
Westerly , Rhode Island
If this is an attempt to place an order, it's not how the internet works.
smithcreek is offline   Reply With Quote
Old 11-19-2018, 10:06 PM   #11
I was told by Airstream service that they were unable to locate these parts anywhere and it would take 2 weeks.
As you all indicted they are readily available all over the place. Not sure why one of the largest Airstream dealers in the country cannot find the parts.
Old 11-19-2018, 10:09 PM   #12
I am at an Airstream dealer. They should know how to get the parts need better than I. Not the case. Once they provided me with the part numbers I can find them easily. Why canít Airstream service do that instead of stranding me for two weeks. Iím not in the middle of the desert. Iím in Los Angeles.
Old 11-20-2018, 12:30 AM   #13
Airstream dealer probably does not have stock of brake parts. Iíd also bet you can find those parts a bunch cheaper than trying to buy them from Airstream.
Dealer competence varies wildly. Thatís why I do my own work if at all possible. Iím sure Iím not the only one with that attitude on these forums.
All else fails, order the parts online, and have someone install them for you if you donít have the tools or experience to deal with the repairs yourself. Itís how the world works at times...
Not really an Airstream factory issue. Blame the dealer.
Old 11-20-2018, 06:40 AM   #14
Do you really not understand the difference between wholesale and retail?
Airstream Brake drums Backing Plates Bearings 6000# axl eBay Watch Airstreams on eBay 0 05-16-2009 03:20 PM
Airstream Brake drums Backing Plates Bearings 6000# axl eBay Watch Airstreams on eBay 0 05-14-2009 10:40 AM
Dexter disc brake failure - stranded in Medford Pecos Pete Brakes & Brake Controllers 7 07-01-2007 11:34 PM
New brake drums or studs????? bhayden Brakes & Brake Controllers 2 05-08-2007 05:13 AM
Brake drums Airstream 1975! Brakes & Brake Controllers 3 03-13-2004 12:27 AM
