Can you use a prodigy controller with a hydraulic pump like this or electric brakes only.The instructions say its not intended for use with electric-hydraulic brake systems.I replaced a vacuum powered booster type system.Is this the system they are reffering to.
The way I understand it, the cheaper the better as far as brake controllers for elctric/hydraulic units. The reason being the more expensive, ie..Prodigy, unit have diagnostic features built into them, they send periodic micro pulses to the brakes to check continuity, connection, condition, this tends to confuse the circuitry in the microprocessor of the hydraulic units and I suppose can cause it engage or act eratic at times. There is a note in the Prodigy set up stating not to be used with these units. Try a Tekonsha 9030, less than $100 and a bullet-proff brake control.
I am not sure of that. A continuity check would consist of a fairly low voltage pulse of a duration fast enough to never get into the response time of the brakes/actuator.
in the case of the Dexter E/H unit - it takes 2 volts output to get the unit to start pumping in the first place. This is (I believe) to allow the unit to not run at stop lights, etc where it is not really needed.
So I am guessing that any brake actuator that will put out between 0 and 12 volts output will probably operate that E/H unit just fine.
I may be way off base on this though and when I got my unit, also got the Dexter actuator that was recomended for that unit. So I can't actually speak with any authority beyong my knowledge of electronics and control systems.
Thanks buttercup.I was going to private message you about this knowing you have this unit.I talked to a dexter rep if the prodigy would work but at the time I did'nt realize the instuctions state that it is'nt designed for electric-hydraulic brakes,rep said it would work.Now I want to make sure.I got a name Jim Miller (a dexter know it all)he works there at 5745957888 Im calling him tomarrow and I'll see what he says.Thanks for the reply.
Just a tip. Tekonsha states that as their policy because some electric over hydraulic units can work and others cant most notable is the carlisle and dexter. Because of this they came up with a policy saying it does not work. They have no invested interest that it does or it leaves them open to create their own. The correct response is the electric over hydraulic units circuit board does not know how to determine the difference between the diagnostics check and real braking. Meaning you buy a very expensive unit to put cheap brake control with it.
A non circuit sensing controller should be used with the new as well as old style disc brake actuators.
There are several types that work very well.
Cost in this case, is almost secondary, in that the expensive controllers will not get the job done, "correctly".
It has also been reported that Dexter has some major problems with their actuator.
O.K. So I have just spent the better part of an hour on Google and can find no documentation that even suggests any problems whatsoever with Dexter actuators. I did find one listing where a motor burned up on a actuator - after running for 57 minutes straight.
Andy, unless you can produce some sort of documentation or reference to that statement, I'll consider it as just hearsay.
The folks at Kodiak already had a deal to supply disc brakes to Airstream when Airstream decided to switch to the Dexter axle - that's why we see the Actibrake.
The Dexter EH actuator is an excellent choice, as my experience with it has proven. I use a Prodigy brake controller with it.
when I first bought the actuator, there was no testing with the prodigy product, so it was not approved. A short while later, Dexter engineering had finished testing the Prodigy as well as Ford's inboard controllers with their product and have officially approved it.
I have absolutely 0 complaints with my Dexter actuator, the performance of the disc brakes with this unit is simply amazing.
Just the other day KenJ, while leading me to his house, made a quick turn preceded by hard braking, so I had to nail the brakes in order to avoid hitting him, and make the turn as well....no problem. This was from 50mph, going downhill alongside I-40 east of Albuquerque.
The braking performance is smooth, linear, quiet, and I am yet to experience any brake fade, whatsoever.
The prodigy does have some boost functions that make the brakes feel funny. I use mine in standard operating mode, with none of the functions activated. Perhaps that is the reason Prodigy says no to EH actuators. But then, I never did read the complete manual.
I talked to Jim Miller at dexter and he told me the first generation actuators would'nt work.The new actuators have barreled tanks.They have added circuitry that sends a signal back to the controller.I hooked mine up today and bleed my brakes.The only thing I had to do is put the controller on b2 and turn the boost control (the knob on the left)all the way up to get enough voltage to activate the pump at a stand still.(3 volts).If it does'nt feel right in motion Im going to change that.I have'nt driven it yet.My brakes are work'in and this baby's ready for a test drive tommarrow.You guy's are awesome wish me luck.
While standing still (vehicle not moving), I used the level to get me just below the 2 volts that I need to start the pump.
With that set I adjust the gain to get me the amount of braking that I need when rolling. This was all I needed. It does work that way.
