Old 01-17-2011, 09:22 AM   #1
REBurt's Avatar
1987 32' Excella
Morrilton , Arkansas
Couple of mixed questions Brakes & balancing
We have out 92 Excella at The Trailer Store in Blackwell, Arkansas (very busy stock/utility trailer store) having the brakes fixed and axle bearings repacked. They jacked up the AS before we got there this morning - even though we asked them to to call us before doing anything to the AS. The axles appear to be fine, they are at about 22 degrees according to the service manager. The questions are: 1) They jacked up the AS at the jack points and put jack stands under the frame just aft of the rear stabilizer jacks, is that a problem? 2) They suggested we replace the brake backing plates as it would be cheaper than repairing the brakes piecemeal, is there any problem taking that approach? The brakes are 12 inch drums. The backing plate comes with the shoes, magnets, springs, etc. 3) They didn't mark the tires and drums so they could be oriented correctly on reassembly. They say you no longer need to worry about balancing the tires and drums as a unit, just the tires nowadays. Is this correct or will we need to have the tires and drums balanced as a unit when we replace the tires? Does any tire store still balance tires and drums as a unit?
I appreciate your assistance in these inquiries.
1987 32ft Excella
2004 Red Dodge RAM 2500HD Turbo Diesel
A bad day on the road is better than a good day on the job - but it's still bad !!!
REBurt is offline   Reply With Quote
Old 01-17-2011, 09:40 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
It is cheaper and easier to replace the brakes as an assembly so that is fine.
Regarding the balancing, the drums may or may not be in balance so it is better to balance the whole works if you can. Not sure if you can even find some one to do it anymore.
Dexter has told me they do not balance their drums, and it is obvious as they will usually rotate back to the same spot. Don't know about others..
You also have the option of putting Dynabeads in the tires or buying centramatic balancers,
In the case of my present trailer I only balance the tires themselves and have no problems but that is not always the case
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-17-2011, 10:04 AM   #3
Having balanced running gear is very important to any Airstream.
Airstreams flex from bumps and vibrations.
Old 04-16-2011, 09:51 PM   #4
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
So how do we get balanced running gear?
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 04-16-2011, 10:33 PM   #5
1985 31' Excella
Fresno , Texas
Go to Andy's Web page Inland RV Center and look at the centramatic balancing he has. I am planning on ordering some from him. There are manufactured south of Fort Worth. I went by there place Friday and there was a Argosy in their shop getting its new centramatic balance discs. I had been looking into them even before I knew Inland RV was a source.
Wsmith is offline   Reply With Quote
Old 04-16-2011, 10:49 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, your drums are not balanced; They don't have any weights welded on them, no drill or grind marks on them, and they are not fully machined inside and out. So just balancing the wheels will not complete the job. I have my wheels balanced and installed Centramatics. Some people use Dyna-beads; Same basic idea, different way of doing the same thing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-17-2011, 10:36 AM   #7
Hate to tell you, but the shock in the left hand photo, is upside down. Not good.
Old 04-17-2011, 07:58 PM   #8
Fuil-Timers
Images: 38
The local brake shop can turn the drums for me but cannot machine the drum's flat surface for the magnets. Is this necessary and do i need a machine shop or just a different brake shop?
Living the Dream
Jim Cocke,
dreamstreamr.com
Old 04-17-2011, 09:59 PM   #9
Salem , Oregon
Images: 18
Hi, Andy. This is the only picture like this that I have; And as I told you once before the problem has been fixed. For those who want to know the whole story about my up-side-down shocks, check out my blog. Click on my Blog Entries, under my Avatar.
2005 Safari 25-B
Old 04-17-2011, 10:06 PM   #10
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Yup.. I remember that story.
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 04-17-2011, 10:08 PM   #11
Salem , Oregon
Images: 18
Hi, I had a friend of mine turn my drums at his shop, but we were unable to machine the magnet part. I was referred to an auto parts store that could do them. They had to modify the bit/blade holder on their machine to do it. They would not let me see their machine. [top secret] Now they have closed up shop, so I don't know where I will get them done next time. Most places just want to sell you new drums.
2005 Safari 25-B
Old 04-18-2011, 11:57 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
Are they scored or just showing a little corrosion? If there's just some rust you can clean it up with a nylon pad on a die grinder. Otherwise you might be better off replacing the drums.
Old 04-18-2011, 12:06 PM   #13
dznf0g's Avatar
Oswego , Illinois
I would suggest, also, that if you just have shallow grooves (.030 or less) you can just put new magnets on an they will seat in fine. You wil probably have to set the apply settings a little higher until they mate, but it won't take too many miles.
Old 04-18-2011, 12:10 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
There is a place by me that does it. I'll be visiting them in a few weeks. Either older brake and alignment shops, or speed shops, are the best places to call.
I have read through all the many threads on balancing that we have here. Several themes emerge:
1) Few shops have the equipment Inland RV uses to static balance hubs and drums. This equipment is no longer made and there is no equivalent product presently being sold to the automotive repair trade, because the received wisdom in the industry is that modern hubs, rotors, and drums are made to sufficiently close tolerances that balancing in the field isn't necessary
2) Few shops have the equipment to perform on-vehicle balancing because of the safety hazards inherent in the process.
3) The few people (2-3) who have actually had on-axle balancing performed have said that there was a significant amount of weight required to bring the entire assembly into balance, compared to the weight present from balancing the wheel and tire only.
4) There are several reports that the current production hubs and drums from Dexter and others, while not perfect, are not as badly out of balance as was typically the case in the 60s and 70s.
5) People with Centramatics seem to like them.
Questions on wiring brakes and lights the544man Brakes & Brake Controllers 7 02-14-2011 07:20 PM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
Couple Sues Walmart FLYNCLD Off Topic Forum 55 01-05-2011 01:12 PM
