Old 10-03-2006, 06:09 PM   #1
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Cooked??
Oh, please do not tell me that I cooked my electric brakes. Today I walked behind my pick-up and there hooked to my bumper was the cable and pin to my emergency AS brakes. It has been on the bumper for 5 days since I used the truck to position the AS in front of the garage. We had just returned from a few days camping. Did I do any damage? The battery was run down the following day but I guessed it was the 3 days of boondocking. I plugged into shore power and the battery is now recharged without the e-brake pin.
Neil.
Old 10-03-2006, 06:28 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you're REALLY lucky, you blew a fuse. I know I am not that lucky. Plug your 12v feed wire in your plug to the electric brake wire, and see if any of the brakes are making a humming sound, if so, they are working. If not, check the fuses. They shouldn't be wired that way, but they could be. If everything is good, and you have no hum, and a small compass doesn't point at the wheels with power applied, you probably have fried the magnets. If everything works, but the breakaway switch, you got lucky and toasted the switch, and a new one is relatively cheap.
Old 10-03-2006, 07:55 PM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Vintage Trailer Supply has the breakawy switch on sale right now for around $13.00, IIRC. Lets hope it's nothing too serious.
www.nesa.org
Air No. 6427
Old 10-06-2006, 05:45 PM   #4
FreshAir's Avatar
1966 24' Tradewind
NOT cooked!
Neil.
I just tested my brake magnets as suggested by overlander63. I found a compass and activated the brakes but as I approached the wheels I could hear the humming even with my hearing aids volume low. So that is a relief. I thought then to test the break-away switch. I pulled the pin but no sound was coming from the wheels. That switch was either fried or did not ever work. I will pick up and install a new one. Thanks for the help.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-06-2006, 05:59 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
What luck! A bad breakaway switch saved your brake magnets.
Richard
Old 10-06-2006, 09:23 PM   #6
TIMEMACHINE's Avatar
Huntington Beach , California
We should learn from this
The lesson here is that we should check our brake switches regularly. Anholman was lucky for two reasons, he didnt fry his brakes and he didnt have an emergency that needed a working brake switch.
John
TIMEMACHINE is offline   Reply With Quote
Old 10-18-2006, 01:25 AM   #7
FreshAir's Avatar
1966 24' Tradewind
Severed wire
Neil.
I removed the 'faulty' breakaway switch to discover that its lead wire was severed where it begins to disappear into the trailer tongue. It was hanging by it's insulation and appeared normal until I touched it. I removed the switch and tested it. It works! What a strange chain of events. So, lesson learned. Everyone, check those switches as religiously as you check your smoke detectors.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Boiling Battery Killo1 Batteries, Univolts, Converters & Inverters 9 07-09-2006 11:00 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Chicagoland Rally announcement!!! Silvertwinkie Forum Rallies & Meet Ups 38 07-14-2003 07:49 AM
univolt mark 5 john hd Electrical - Systems, Generators, Batteries & Solar 25 04-20-2003 07:42 AM
Rallies for M - F working class in SoCal GoldFever Forum Rallies & Meet Ups 54 12-10-2002 11:54 AM
