Old 12-01-2011, 03:13 PM   #57
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
(cut off again)
With experimentation and making my rig as familiar as possible with best numbers, I can then try to sort: is the "feeling" I'm getting the fact that I'm climbing in/out of the big truck ruts . . or are my tie rods and/or anti-roll bar links/bushings increasingly sloppy due to time/miles? And so forth.
Try to get the WD out of that loop.
Can only get there by: Work the numbers, stay up with load changes (tickets), and fine tune.
Old 12-01-2011, 05:29 PM   #58
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Andy,
I have tried adding that 100lbs to the TV steering, no difference, trailer is level when using original setting. And it really doesn't make a difference in drivability.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 12-01-2011, 05:37 PM   #59
1981 31' Excella II
New Market , Alabama
Guys I don't think you are going to get NASCAR performance out of your RIGS. What if you get the balance just perfect and you did it with an empty gas tank. I know you can have two gas tanks one in front and the other in the back to keep the load balanced. All kidding a side we should not be driving at the limits of what the system is theoretically possible. I think just getting close is good enough. Just having some sort of weight distribuition and some sort of sway control is going to make things much better than none at all.
Perry
Old 12-01-2011, 05:42 PM   #60
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Keep working the range of adjustments on new trips with new loadings. Then you'll know the range of changes from a 3-day to a 3-month trip. Afterwards, any changes are easy. The difference between full holding tanks and none is worth knowing, for example.
Old 12-01-2011, 06:20 PM   #61
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by ROBERT CROSS View Post
Andy,
It's the lack of WD to the TT axles also, not just the FA. The Drive Axle can afford to shed some of the 1,180-lbs it has picked up with WD activated, looked at from either approach. Only a bare amount of WD is occurring.
Old 12-01-2011, 06:30 PM   #62
Thumbs up
It's a 5500lb rated rear axle...
WD is pretty much right-on... set anywhere between 50% and 85%.
When fully loaded, 85 works best, ticket #3. 100lb lite on str axle.
But Level!!
PFC
"Tahawus"
RLC
John Prine
Old 12-01-2011, 08:24 PM   #63
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Okay, (and you're a big boy on this stuff, not a newbie, so bear with me)
why not some forward hitch head tilt?
That'll move some weight both onto the FA and the TT?
IOW, why run the RA at max?.
Edit: Read your sig. Forgot that you have the same second-rate VPP hitch that I have, the nearly un-adjustable Hensley. With my concrete truck Dodge springs I got zip WD. Truck had no problem running at nearly 6k on the RA, but it was frustrating nonetheless. Swapped stingers twice (and this with a leaf-sprung trailer, not IS).
The Pro Pride solves this deficiency. My next hitch (and there will be one) will be either that or a Pullrite.
"trailer level" . . yeah, I get it. That great 'Nam rejoinder: Don't mean nothin, drive on.
Old 12-02-2011, 05:54 AM   #64
1981 31' Excella II
I would expect your tow vehicle with the tail way low would be bad because then the trailer would tend to push the front wheels off the ground when stopping. This is assuming the trailer brakes don't have enough stopping power to stop the trailer on their own and most don't. Level is best. Tail high is probably not good either especially if you have little or not brakes on the trailer.
Perry
Old 12-02-2011, 11:51 AM   #65
Thumbs up Take into account...
Consider>>the Classic is equipped with 2 3500lb axles, 7300max.
TV rear axle rating 5500lbs. Max camping load on TV rear axles..4680lb.
Margin?
TV str axle 100lb under unloaded weight. Not with-in margin?
AS axles...7640Lb>>340lb over. Not good. ... but doable.
ID:	146355   Click image for larger version
Name:	CAT Weights.jpeg
PFC
"Tahawus"
RLC
John Prine
Old 12-02-2011, 07:23 PM   #66
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The beauty of numbers. I can see why you do what you do (which is why I asked). I did think that the TT was heavier than it is, and thereby assumed (as well) that there was room for more weight transfer fore and aft. You certainly had me puzzled, so I had to deflect it onto the hitch (on which nothing will change my opinion short of an adjusting head).
Thanks for filling in the gaps. I learn from all of these examinations so am appreciative of the full picture.
Nascar aside, it is neither nitpicking nor effort wrongly expended, IMO . . this, on a week with two threads about TT's/TV's and a driver seriously damaged/injured (or destroyed) while en route. Confidence in one's rig is validated by numbers.
The best hitch rigging is -- like the best brakes [disc] -- a control device[s] ideally manipulated by the driver involving the least effort and smoothest feedback.
The Test is not the time to learn of, or regret, any shortcomings.
Old 12-24-2011, 09:08 PM   #67
Halimer
2006 25' Classic
New Hyde Park , New York
Ricky,
I saw you want to order the F150 with the max tow option. You realize Ford is also offering a Heavy Duty option. To the best of my knowledge there is a substantial increase in the payload capacity. It includes LT tires slightly larger frame, 7 lug wheels and a few other HD tow options. Check things out on the Ford Fleet site:https://www.fleet.ford.com/truckbbas...12_F150_SB.pdf
Mark
halimer is offline   Reply With Quote
Breakaway brakes Buffalo Brakes & Brake Controllers 5 03-31-2012 06:11 AM
New TV and prodigy and cooked TV brakes Goin camping Brakes & Brake Controllers 5 08-14-2011 08:21 PM
ITBC on 2011 Silverado locks up AS brakes MikeAir Brakes & Brake Controllers 7 08-04-2011 06:14 AM
Hensley or Disc Brakes? DFDureiko Brakes & Brake Controllers 22 05-02-2011 01:57 PM
