Old 11-17-2011, 02:09 PM   #15
1981 31' Excella II
New Market , Alabama
Well I have had my share of electrical brake problems. I have had a heck of a time getting them balanced so one wheel does not lock way before the others. I just about ruined one new tire this way already.
Perry
Old 11-17-2011, 03:02 PM   #16
2006 30' Classic
Milton , Florida
Originally Posted by perryg114 View Post
Yeah I am thinking that as well now that I have read about the problems with the disk systems. Now if I were towing with one of them thar VW things disk brakes might be a better option.
Perry
A properly designed and installed hydraulic disc brake system is far superior to an electric drum brake system.
If you research the two types of systems, you will find that hydraulic disc brakes are far superior in terms of stopping ability and maintenance issues, as compared to electric drum brakes.
Essentially all of the problems associated with hydraulic disc brakes on Air Stream trailers can be traced to problems with the Actibrake hydraulic actuators, and design faults in how Airstream installed the units (badly kinked brake hoses).
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 11-17-2011, 05:59 PM   #17
1981 31' Excella II
Well at this point disk brakes are not in the budget but maybe someday. If I towed a lot in the mountains I would think disk brakes would be a good idea. Towing on flat ground at moderate speeds I am not sure it is worth the expense. I make a couple long trips to Florida from North Alabama at this point and probably some sort trips to camp around here. We may go to NC this summer in persuit of places without high heat and high humidity. When it is cold we vacation south. When it is hot we go to the mountains where it is cool. You guys that camp in the dessert in the summer are nuts.
Perry
Old 11-17-2011, 10:13 PM   #18
Tool Hoarder
West , California
I wouldn't try to convert drum to disk brakes. I went disk brakes because I went with new axles. I am going to install the Titan brake actuator.
marzboy is offline   Reply With Quote
Old 11-18-2011, 07:26 AM   #19
What is the response time, and maximum pressure compared to the others?
I did not see that listed.
Old 11-18-2011, 08:52 AM   #20
Tool Hoarder
West , California
Hi Andy I have it written down somewhere. Have to get back to you on it. Wierd that its not in the tec specs though...
What are the specs for the others you have listed? The nice thing about the Titan is the brain is seperate from the rest of the unit. From what I hear that is what goes bad.
Thanks for your imput.
Ps I will be seeing you guys pretty soon for more parts!
Old 11-18-2011, 11:15 AM   #21
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Disc brakes are over rated according to Chevy. They don't even put them on all four wheels on the Silverado 1500. <ducking for cover>
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 11-20-2011, 08:17 AM   #22
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
newroswell,
Your signature quote is a gem, thanks for the grin.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-20-2011, 09:52 AM   #23
2011 25' FB Flying Cloud
chalk hill , Pennsylvania
thread's making me consider disc conversion...
just about to take bring home my 03 28ft classic. I live in the Laurel mountains in Pa. and my trips will always involve some pretty good decents. Who provides complete disc brake upgrade kits. etrailer has a bunch of kits, but i can't tell which will work. I know they're expensive, but I'd like stainless calipers, i hate rust!
Getahobby is offline   Reply With Quote
Old 11-20-2011, 12:29 PM   #24
GCinSC2's Avatar
fairchance,
Sorry, can't help on the product, but Laurel Highlands, wow beautiful region and yup, I bet if you go disc brakes with a premium controller, you'll appreciate the decision on your hills. Many others here have more years and miles that I with an AS, but I have had my share of brake/hydraulic issues for several unrelated issues, I do like my MaxBrake, it makes sense, tap into your hydraulic system to create a signal via transducer for your controller to communicate with the actuator.
Doesn't Kodiak offer kits? I watched an install video from them a couple of years back.
As you get closer, find the Tech Support Guru from the mfgr, get their name, extension, e-mail, make notes and go over the details until you can recite it backwards and forwards.
Good luck.
S/OS #001
Old 11-20-2011, 01:10 PM   #25
Maniacal Engineer
barts's Avatar
Menlo Park , California
Kodiak is the brand that I got w/ the axles from Andy; easy to understand directions and good quality parts & hardware. I mounted the brake unit next to the batteries under the (custom) rear dinette seat in the Tin Pickle. Figure on spending a long day underneath the trailer running brake lines & bleeding them - not difficult, just work.
As others have noted, make sure that the brake hoses have sufficient slack under all conditions. Doing a good job of bleeding the brakes is very important to reduce brake delay - persistence here will pay off.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-21-2011, 07:02 AM   #26
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
2Air made some comments about stainless components a couple of years back. I'd search for that older thread.
Old 11-22-2011, 03:45 PM   #27
1981 31' Excella II
So how do these pumps work? Is it a rotary hydraulic pump or something more crude? Maybe a power steering pump driven by some sort of electric motor and a porportioning valve?
Perry
Old 11-22-2011, 05:47 PM   #28
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Perry,
Get a cold one
http://www.trailerpartsdepot.com/mmn.../actibrake.pdf
http://www.expediter.com/pdf%20folde...folder/L16.pdf
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Breakaway brakes Buffalo Brakes & Brake Controllers 5 03-31-2012 06:11 AM
New TV and prodigy and cooked TV brakes Goin camping Brakes & Brake Controllers 5 08-14-2011 08:21 PM
ITBC on 2011 Silverado locks up AS brakes MikeAir Brakes & Brake Controllers 7 08-04-2011 06:14 AM
Hensley or Disc Brakes? DFDureiko Brakes & Brake Controllers 22 05-02-2011 01:57 PM
