Old 05-02-2007, 09:18 PM   #1
1971 23' Safari
Beaverton , Oregon
Controller for Disk Brake Retro-fit
First of all, be kind to me this is my first thread. We have a 1971 Safari that is currently being upgraded to disc brakes from the standard electric drum brakes. I'd like to know if my Prodigy brake controller will be compatible with the new electro-hydraullic disc braking system.
rrpranch is offline   Reply With Quote
Old 05-02-2007, 09:35 PM   #2
_
hello rrpranch and welcome to the forums!
what brake system? the actibrake/kodiak many dealers install or something else?
here is a thread to get ya started.
http://www.airforums.com/forums/f439...ler-30440.html
at least some report the prodigy will work...
cheers
2air'
Old 05-02-2007, 09:54 PM   #3
1971 23' Safari
Beaverton , Oregon
Thanks 2air'. Actually the trailer is down in Eugene, OR. getting the installation right now and I don't know which system they are installing. I'll have to give them a jingle tomorrow to find out.
The other thread you alerted me to seems to indicate that the Prodigy will work as long as it's calibrated and you use the boost feature.
Thanks again
Pete
Old 05-02-2007, 10:04 PM   #4
_
sure pete
if the a/s dealer is doing the work it is likely the kodiak system...
you are gonna LOVE how she stops!
and don't forget to post some photos...
cheers
2air'
Old 05-02-2007, 10:08 PM   #5
1971 23' Safari
Beaverton , Oregon
We are also having the axles aligned, new aluminum wheels installed and new bearings installed. Hopefully this will stop our trailer from making the "wierd, wierd tire wear pattern" (see DMRoot thread in 1969-1973 Safari).
http://www.airforums.com/forums/f420...a-31328-2.html
Old 05-02-2007, 10:19 PM   #6
_
new wheels and bearings, cool!
yes, i've seen those STRANGE tire wear patterns....
and haven't a clue to the cause.
are you getting new axles too? are the 36 year old ones still riding properly?
inland andy never commented on your tire pattern...
and often the response is 'balance that running gear'...
but i wondered IF one shot axle or even one shot side could cause some of that funky wear...
keep us updated...
cheers
2air'
Old 05-03-2007, 08:43 AM   #7
1971 23' Safari
Beaverton , Oregon
Yes. We are having the axles checked. I looked at them pretty closely before dropping the trailer at the shop and they still have a decent camber to them. So we're having the shop check the alignment. The tech at the shop seemed to think that the tire wear pattern may have been caused by loose bearings. All I know for sure is that previous owners dragged that trailer a loooonnnngggg way with poorly adjusted running gear!
Pete
Jordan Research Ultima Brake Controller RoadKingMoe On The Road... 0 09-26-2002 12:41 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 12:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
