Old 11-20-2012, 05:00 PM   #1
Smoky's Avatar
Eau Claire , Wisconsin
Images: 8
Common ground?
Can I just run the blue brake wire to all four wheels of my dual axle trailer and just run a short ground wire from each magnet and attach to the axle? I read electric brakes should have a common ground, but isn't the entire frame the ground?
1961 Avion T-27
Smoky is offline   Reply With Quote
Old 11-20-2012, 05:18 PM   #2
1974 Argosy 20
Kooskia , Idaho
That's a tough one to answer. In theory the frame is a ground (negative) for the entire 12 volt system and you should be able to ground locally to the wheels. However, that gives you four more points of possible problems. If I were to do it, I would use a common ground wire and make a super good single ground connection to one point on the frame, or even to the negative lead which comes from the TV cord (or both).
You want brakes to be reliable, always, and they are critical safety issue items. I guess I learned a lesson when at 65 mph, I came very, very close to rear ending a compact car and pushing him under a tractor/trailer. I found 3 of the 4 brakes on my AS were not working. Yikes! Two were wiring problems, one was a mechanical issue. Never again.
Old 11-20-2012, 05:25 PM   #3
Smoky's Avatar
Images: 8
Yes, that makes sense to have just one ground screw to the frame instead of multiple ground locations. Thanks.
1961 Avion T-27
