Old 04-24-2010, 09:35 PM   #1
2016 30' Classic
Sandpoint , Idaho
Chev 2500HD Factory Trailer Harness Issue
My P3 controller is not getting a signal from my TV brake switch. The switch is working properly, i.e., the TV brake lights work fine, but 12v is not making it to the pin the P3 adapter harness plugs into. I've checked the fuses under the hood and they're good. Any ideas before I have to bypass the vehicle trailer harness and splice directly into the brake switch wiring?
terryg is offline   Reply With Quote
Old 04-24-2010, 10:21 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, just trying to help, but how did you check the fuses? GM is well known for installing dummy fuses in places needed for trailers. This has been mostly noted on people who's trailers have disk brakes.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-24-2010, 10:24 PM   #3
redeagle313's Avatar
NE , Indiana
What model year is your 2500HD?
Have you ever been to The Diesel Place? It is a GM HD truck owner forum, you can probably find answers very quickly there.
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 04-25-2010, 03:32 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
fuse!
In my 2008 I had to install both a fuse and a wire. Both were under the hood on the driver's side. I don't remember whether the instructions were in the brake controller pamplet or the owner's manual. I'll look but I'm not great saver of paperwork.
Paula
Old 04-25-2010, 01:07 PM   #5
2016 30' Classic
Sandpoint , Idaho
Thanks for all the suggestions. My Chev is a 2004 Duramax. Everything was working last fall when I put the trailer in storage, but somewhere in the circuit continuity was lost during the winter. After checking all the obvious things with no luck I decided to splice directly to the brake switch. Everything is working fine now. Terry
Trailer harness and running lights 64TrotterAtl Electrical - Systems, Generators, Batteries & Solar 8 10-09-2008 10:07 AM
96 Blazer with factory trailer hitch - towing capacity? BlazinHaze Tow Vehicles 21 09-02-2008 09:44 PM
'08 GM 2500 trailer wiring / safety issue? AirsDream Tow Vehicles 9 04-09-2008 08:02 PM
Trailer Life Mag Airsteram articles in May 06 issue munimula Airstream "In the News" 1 04-13-2006 04:48 PM
