Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-20-2005, 10:37 AM   #1
Cracker
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
Thumbs down Check the Brake Controller
Just a reminder to periodically check the settings on your brake controller! On my way home from a recent trip I was forced into an emergency braking situation due to a left lane closure that was posted, but ignored by a large group of drivers until the last minute. The offending drivers switched to the right lane, just after cresting a hill, filling the gaps, and braking hard to avoid colliding with the respective cars ahead of them. What I thought had been a reasonable separation for the reduced speed zone quickly deteriorated. Braking hard, I headed for the emergency lane with the trailer wheels locked and smoking, only microseconds ahead of an identical maneuver by the driver immediately ahead of me! I then turned back into the travel lane to enter the space he had just vacated, bringing the rig under control with only a few feet to spare.
As in almost any rear end collision situation I would have been at fault if I had collided with the car ahead of me. The point of this long-winded story is that I had not re-set or tested my Prodigy controller since I can't remember when. The setting was at the maximum for the trailer - a full 12 volts - which caused the early lock-up of the trailer wheels. Since the road was dry, the quick swerve to the emergency lane, followed by a return to the driving lane, only caused the start of a jack knife - and not the full monty!
I plan, hereinafter, to make it a point to check my controller settings at the start of every trip. I have no idea how the controller got moved to the highest setting - but suffice it to say I have grandchildren that love to crawl around in Grampy's truck!
Cracker
Cracker is offline   Reply With Quote
Old 07-20-2005, 10:49 AM   #2
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Glad you made it through that scary moment. It brings up a good issue.
I was going to post about setting brake controllers and have never gotten around to it.
What is the proper way to set a brake controller? I have a voyager.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-20-2005, 03:13 PM   #3
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My way to set my controller is to find a flat street or parking lot, get the speed up to 20-25 mph, and then manually activate your brake controller to fully activate it. The gain is set to about 50%. If the trailer brakes lock the wheels, I back off the gain a small amount. I continue the test again until I can get the maximum amout of braking force just short of locking the trailer wheels up. That's your best braking performance under worst case conditions when full power is being applied to the brakes. I mark that setting on the controller in case it gets moved.
Now I do make adjustments on the road, especially if in wet weather where I might find the gain to be slightly too agressive for road conditions (wheels locking).
Even though I have used about 4 different controllers in my towing history, the process seems to be pretty similar. Some controllers may contain an extra button that compensates for the weight of your trailer (affects the amount of power delivered to the brakes). Sort of a preset gain that works in conjunction with the gain knob.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 07-20-2005, 05:55 PM   #4
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I currently have the Prodgiy...I use it in 3 different trucks with 5 different trailers I made a little sticker for each truck with the different setting required for each trailer. It isn't perfect but gets me in the ball park and I can make minor adjustments as needed. What is interesting to me is that both my Coleman Popup and the Airstream use the same setting except I use the first boost level on the Airstream...go figure.
Aaron
WBCCI #2449 AIR #2495
Old 07-20-2005, 06:09 PM   #5
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Thumbs down
Just one thing to mention in passing. My rig sits outside and I have found that the shoes grab for the first 10 or so applications and smooth out afterward. Probably due to slight rust insde the drums. They are really bad the first time out. If the controller is adjusted OK at the start of the trip the brakes may feel "loose" at the end.
I usually tweak the settings when I get out of the towns and on the open road.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 07-21-2005, 08:47 AM   #6
Cracker
Cracker's Avatar
Pittsfield , Maine
The minor inconvenience with the Prodigy (---which I use) is that the vehicle has to be stopped in order to set the energy level. It would be nice if you could simply dial a lower number in - or reset the boost - when it starts to rain and you don't have any place to pull over. One of these days maybe we'll get a heads-up display on our instrument panel that gives us the settings and allows us to make changes while underway. It's my dream - but maybe one of the big three will figure out what a lot of us are using their trucks for - "towing!" At least Ford has become to include a brake controller as standard equipment. On the other hand, I don't know why you couldn't provide the aforementioned "heads-up" display via a remote "stick-on" LED display plugged/wired into one of the present family of controllers???
As an aside, with the current trend towards disc brakes on trailers, a more sophisticated controller is probably overdue.
Cracker
Jordan Research Ultima Brake Controller RoadKingMoe On The Road... 0 09-26-2002 01:41 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 09:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 01:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 11:11 AM
