Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-23-2003, 09:40 PM   #1
Navigator
Profile:
Capacitors on Older Electric Brakes
Have a 1973 31 ft Soverign with tandem axles. Behind each wheel is a 1" X 4" capacitor with a lead in wire and a metal bleeder rod. All 4 capacitors are interconnected. I assume that the interconnected lead in wire goes to the + electric brake wire?
My question is what is the function of those capacitors???
Will the brakes work w/o them?
Thanks in advance for any information.
Dick
Navigator is offline   Reply With Quote
Old 11-24-2003, 08:26 AM   #2
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Never heard of capacitors in an electrical brake system. Brake system should work with out them. A capacitor is a short term electrical storage devise. I don't understand that function in a brake system unless there were spikes and then there would be a second applicat ion of the brakes.
>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 11-24-2003, 12:04 PM   #3
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Question radio noise?
perhaps a previous owner was a ham radio operator and installed the caps to quell radio noise.
can't think of any better reason.
john
you call them ferrets, i call them weasels.
Old 11-24-2003, 02:55 PM   #4
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Capacitors
Can you tell the value ??
.001 to .01ufd would be for electrical noise suppression. Other than that I know of no reason to have caps in the brake ckt.
Garry
Old 11-24-2003, 05:37 PM   #5
Navigator
Profile:
Thanks for the reply gentlemen.
My guess now is they act as sort of a voltage unifying device so that all 4 brakes see the same voltage??
Anyway since 2 of the bleeder rods were corroded back to the base, I bypassed them. Now when I apply max voltage only 1 wheel locks up. The good news is that it passed inspection. Now I can legally tow it to a shop for new axles etc.
Dick
Old 11-24-2003, 05:47 PM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Navigator.
The capacitors were used to eliminate "radio" interference for a "Ham" operator.
You can remove them if you wish, as normally, a capacitor serves no other useful purpose.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-25-2003, 02:39 AM   #7
Navigator
Profile:
Thank you Andy.
Dick
