Old 07-02-2014, 09:13 AM   #1
Blockstream's Avatar
Can I tow my 25ft Safari without using my Prodigy Brake Controller?
I recently purchased a new tow vehicle and have yet to install my Prodigy Brake Controller. However, I need to move my 25ft Safari about 20 miles down the road. I was wondering if anyone could give me insight as to how safe or unsafe it would be to tow my Airstream a short distance without a Brake Controller. Thanks in advance!
Blockstream is offline   Reply With Quote
Old 07-02-2014, 09:17 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If you have a one ton pickup with disc brakes and the roads are on the level, you might get away with it, but most states require operational trailer brakes on trailer GVW exceeding 3,000 pounds.
Your insurance on both the truck and trailer might be invalid for the trip.
Old 07-02-2014, 09:43 AM   #3
My tow vehicle is a 2013 Land Rover LR4, which does have disc brakes and the roads are level, but I think you're right and Connecticut requires a brake controller. I'll wait for my part to arrive and install the Prodigy before towing my Safari. Many thanks for your input!
Old 07-02-2014, 10:03 AM   #4
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I towed my AS home with an F150 130 miles on flat ground without brakes when I bought it. If your trip is anything like the mountain pass in your avatar I would not do it! If flat ground, be careful.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-02-2014, 10:39 AM   #5
1974 Argosy 20
Kooskia , Idaho
It is never safe, or legal to tow a 25' trailer without brakes, one mile or 20 miles or 1000 miles. What happens if a kid dart out in front of you and you cannot stop? Or another car?
Sure, you can risk it, but safe... not.
Old 07-02-2014, 07:05 PM   #6
1981 31' Excella II
New Market , Alabama
If you are going to be driving on flat back roads I don't see a problem. Lots of stop and go traffic would not be good. Test the rig and see how long it takes to stop and take that into account. I would stay under 50. If you have a sway issue you have no brakes to get it under control. If you were electrically inclined you could rig a resistor to a brake circuit or something to get at least some degree of braking. A standard brake controller just applies 100 percent braking after a certain delay. 100 percent being where you set the controller to avoid lockup.
Perry
Old 07-02-2014, 07:09 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Can you? Yes.
Should you? From a legal standpoint absolutely not.
Can you get away with it? Maybe
Aaron
WBCCI #XXXX AIR #2495
Old 07-05-2014, 06:23 AM   #8
Just to sum up the conversation:
I decided to take the wise advice and purchase a new brake controller for my Land Rover. From what I read on a number of websites, it would be easy to install myself. Turns out it wasn't. After pulling apart the under trim near the foot pedals, I couldn't locate the brake controller plug, even I read it would be easy to spot. After searching for an hour I decided to drive to my mechanics shop and ask him to take a look. After searching and searching, he discovered the plug was attached to another socket.... Long story short, we connected the wires, picked up our Safari and drove home without a hitch (no pun intended!).
Thanks for everyone's input!
Old 07-05-2014, 06:27 AM   #9
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
Yes, I had a Range Rover... and they do hide the plug really good.... it is a ford type of plug.
LaBigDogs is offline   Reply With Quote
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
2005 Excursion Diesel and Prodigy Brake Controller-HELP!! LittleRadio Tow Vehicles 13 12-28-2006 03:26 PM
Is Prodigy the best brake controller? silverback 2002 - 2005 International 13 07-28-2003 05:03 AM
Prodigy Brake Controller bdbluegrass Brakes & Brake Controllers 12 04-24-2003 10:14 PM
