Old 09-30-2015, 03:08 PM   #1
2001 25' Safari
Pennsdale , Pennsylvania
Buying trailer brake controller for my Silverado
Just purchased a 2013 Silverado and want to know where to purchase, what type of electric trailer brake to buy, and how hard are they to install. The Silverado is to pull a 2002 Safari that is 25 feet long, also recently purchased, so I'm a nubie.
Next post will be about side view mirror extenders, looked into GM OEM and they're over $600.
DebDonDaisy is offline   Reply With Quote
Old 09-30-2015, 04:16 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Congratulations on your purchase and welcome!
Presume you mean a brake controller, and that you have a Silverado 1500 as opposed to a 2500HD, since they can come with one built in. I installed a Prodigy P3 in my F-150. There was a connector already there in the dash under the steering wheel. I bought the P3 and an adapter cable and just plugged it in and screwed it to the dashboard frame over the gas pedal. It worked great.
Google Prodigy P3 and research the Tekonsha website for compatibility with your Silverado.
There is also a wireless version that is easier to install but, if I remember correctly, costs about twice as much.
Anticipating your next post, there are slip-on trailer mirrors that run about $30/side. I bought a set at Camping World, but they are widely available. Mine worked great.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-30-2015, 04:31 PM   #3
2014 25' FB Flying Cloud
Grand Rapids , Michigan
I second the Prodigy P3 setup, plug and play for our Tundra, just need to find your specific plug. Controller was easy to set up.
We have had a good experience also with the Grand Aero Towing mirrors, they attach with screw clamps and I haven't experienced too much "shake" thus far. They are made by JR Products and available on Amazon amongst other places.
Have fun!
MIFC is offline   Reply With Quote
Old 09-30-2015, 04:50 PM   #4
2008 25' Safari FB SE
Frederick , Maryland
I have the P3 and GM wire harness that I used in my 2001 Silverado 1500. Easy set up and worked well. We sold our truck and have no use for it any longer. Only used a few times. PM me if you are interested.
VWill is offline   Reply With Quote
Old 09-30-2015, 05:05 PM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
The Prodigy P3 is the way to go, hands down. As far as mirrors, look through the web. There are some for as low as 400/pr. Cheap, Good, towing mirrors not happening
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 09-30-2015, 05:30 PM   #6
aftermath's Avatar
Spokane , Washington
What Bruce just said.
aftermath is offline   Reply With Quote
Old 09-30-2015, 06:24 PM   #7
2001 25' Safari
Appreciate the information, especially the clip on mirrors. Will look into the Prodigy P3.
Thank you
Old 10-01-2015, 10:39 AM   #8
2009 23' Flying Cloud
Colorado Springs , Colorado
Check out this video: .
As an alternative, there is an "OEM style" controller available for your Silverado which will give you a cleaner and possibly easier installation. Google "trailer brake controller 2013 silverado" to look at this option.
For your mirrors, look on Amazon for FIT SYSTEM mirrors. They make a nice extension that snaps right onto the truck mirrors.
silvertrails is offline   Reply With Quote
Old 10-01-2015, 02:07 PM   #9
mefly2's Avatar
2015 25' FB Eddie Bauer
If you have the $$, the factory tow mirrors are worth the investment ...
Old 10-01-2015, 04:28 PM   #10
1979 23' Safari
Wayland , New York
You might have a plug under the dash to plug in an after market brake controller. Especially if trailer connection was already wired and installed in the rear. Makes it really easy.
Old 10-01-2015, 10:32 PM   #11
jrolls's Avatar
2005 30' Classic
Brigham City , Utah
My vote is also for the Prodigy P-3. We've used ours on a half ton '02 Burb, 3/4 ton '06 Yukon XL and now a '10 Armada. With regard to towing mirrors, I'd go with the non-OEM versions of the factory towing mirrors. We did that with the Burb and Armada and were/are not disappointed. Yes, they are big, BUT look and perform the best for us.
jrolls is offline   Reply With Quote
Old 10-02-2015, 05:06 AM   #12
Kevin245's Avatar
Ditto on the Tekonsha Prodigy product line. There are many Plug & Go wiring harness options that should allow you to simply plug into the existing factory wiring harness if a connector is not already present". The last install I did on an F-350 took less than 30 minutes, which included adding a new 4 flat/7 blade connector under the rear bumper.
Eleanor Roosevelt
Old 10-02-2015, 08:11 AM   #13
2015 23' International
Charleston , South Carolina
Prodigy is hands down the best. Unlike cheaper controllers, prodigy has sensors that match trailer braking force to that of the TV. Once dialed in for your TV, it is so smooth that you can barely tell the trailer is back there.
FollySteve is offline   Reply With Quote
Old 10-02-2015, 08:30 AM   #14
Denis4x4's Avatar
Durango , Colorado
Costs a little bit more, but the DirectLink is far superior to the Prodigy. I have the DirectLink in my Grand Cherokee and as soon as they make a connector for the M-B Sprinter, I will replace the Prodigy currently installed in the M-B.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Silverado brake controller and hitch pin Jack46 Towing, Tow Vehicles & Hitches 46 03-08-2015 08:59 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
2012 Chevy Silverado 1500 Brake Controller Wiring AirHeadsRus Brakes & Brake Controllers 9 11-20-2011 05:20 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
GM Silverado and Sierra brake controller Pahaska Tow Vehicles 23 11-29-2007 05:17 AM
