Old 05-09-2013, 04:48 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
broken brake wires
After towing 1300 miles I crawled underneath to wire camera only to notice my streetside forward brake wiring totally broken at the splice.
Should I just resplice? I know it needs repair, just seems the crimp connectors are not best for task.
Thanks in advance!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-09-2013, 05:00 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have repaired broken wires on mine with solder and shrink tubing.
Richard
Old 05-09-2013, 06:04 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Either method is fine if done correctly. Might try doing a search "crimp vs soldier". This issue has been debated many times. I would use marine type crimp connectors.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-09-2013, 06:23 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
10/4 on the marine crimp...shrink included.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-09-2013, 07:07 PM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I had similar problems on several wheels and I also replaced all with solder/shrink tube.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-09-2013, 09:19 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Solder and shrink tubing is easy for me. I will see if I can locate marine with shrink tubing
Thanks for verify that is acceptable process.
Channing
WBCCI# 30676
Old 05-10-2013, 04:06 AM   #7
Wink
Good to have some Marine in the tool kit for emergencies, no ac or heat needed.....
.......especially when your water pump takes a dump your first time out and you've got 2sq ft to Mcgyver in, with a closet full of cloths, that aren't allowed to catch fire or get wrinkled, ...hate it when that happens.
PFC
RLC
