Old 02-10-2006, 11:36 AM   #15
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Why didn't I think of this before?
http://www.tekonsha.com/instructions...PDF%20RevG.pdf
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 02-10-2006, 06:54 PM   #16
Tinsel Loaf's Avatar
Why not a small removable wheel on the front jack that acts like an anti-locking brake so the loose trailer will roll in a straight line giving direction with some braking action but not allowing the jack to crumble to the ground while the main wheel brakes stop the run away trailer. Most likely would prevent a lot of A frame damage. You could remove the wheel and put on the foot plate when parked or parked for a long period of time. Another million dollar idea.
Tinsel Loaf is offline   Reply With Quote
Old 03-28-2006, 05:20 AM   #17
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Originally Posted by loudruff
Do not hook to safety chain loop or hitch ball.
NEWBIE ?????
Where are you suppose to hook this? Thanks
enduroryda is offline   Reply With Quote
Old 03-28-2006, 05:42 AM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by enduroryda
NEWBIE ?????
The idea is, if the hitch comes off the frame of the tow vehicle, the breakaway switch will never activate, since it is attached to the part that fell off (along with the trailer).
You can hook the loop through a convenient spot in the bumper, or frame, of the tow vehicle. If the frame falls out from under your tow vehicle, the trailer getting away from you will probably be the least of your problems.
Old 03-28-2006, 06:08 AM   #19
enduroryda's Avatar
1994 21' Sovereign
Thanks Terry
One more ?...In the Reese online info it does not state what the small ball next to the hitch ball is for.....Thanks again
Old 03-28-2006, 07:06 PM   #20
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The small ball is for a friction sway device. You would also mount a ball on the trailer and attach the unit between the two balls. Looks like this
Richard
F-18 Breaking sound barrier FrankR Off Topic Forum 7 12-16-2004 10:11 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 08:06 PM
Why are we breaking records? Ken J Off Topic Forum 5 07-15-2004 06:59 PM
Breaking & Entering Navigator Doors & Locks 4 02-28-2004 07:34 AM
Breaking the 200 mark 83Excella Our Community 1 03-04-2003 08:11 PM
