Old 06-01-2019, 06:14 PM   #1
2018 16' Sport
Killingworth , Connecticut
Breakaway switch underpowered?
Testing breakaway and not getting any reaction from brakes. We swapped out the switch, no difference, and the new switch has an LED indicator that doesnít light up either when pin is pulled. While swapping the switch out, we tried touching blue wires are together the brakes click but donít hum, get a spark so there is definitely current. No problem with TV brakes or controller, and when umbilical is hooked up, brakes hum when pressing TVís brake pedal.
Is it possible that the switch is just not getting enough current? How would this happen? Anyone had the same problem?
teddies is offline   Reply With Quote
Old 06-01-2019, 07:01 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Sounds like your battery is dead perhaps? Voltage and current to energize the brake magnets comes 100% from your 12v battery when you pull the trigger on that switch.....
wulfraat is offline   Reply With Quote
Old 06-01-2019, 07:26 PM   #3
2018 16' Sport
Itís running the lights OK, multimeter reads full voltage, itís weird. Iím plugging into 120 overnight to see if that makes a difference...
Old 06-01-2019, 07:27 PM   #4
2018 16' Sport
Lights are such a low draw maybe i wouldnít notice if it was low.
Old 06-01-2019, 07:33 PM   #5
wulfraat's Avatar
I'd check the water level in your batteries as well while you are at it...
Old 06-03-2019, 12:22 PM   #6
Msherw's Avatar
2018 22' Sport
Blue Sky Ranch , Texas
Just because the LED lights work there is no guarantee the magnets work on the same voltage.
Check the battery with an analyzer that loads it. If that is ok, move to the breakaway switch for diagnosis repair or replacement.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
Ham Radio Call sign K5FT
WBCCI #18673 - of Texas group
Msherw is offline   Reply With Quote
Old 06-03-2019, 01:10 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The brake magnets draw 3 amps each, so a total of 6 amps on your 16' trailer.
Brakes should not hum. They are fed with DC. If you hear a click that is the magnet grabbing the hub. Jack a wheel up, spin it, and pull the pin. Try to turn the wheel. At first it might be easy but then you should not be able to turn it.
They only work going forwards, not in reverse so be sure you are spinning it the right way.
Probably for the LED to light the switch bracket needs a good connection to the trailer frame. If it is mounted on paint, it may not work. That wouldn't affect the brake operation, only the LED.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-05-2019, 03:57 PM   #8
2018 16' Sport
Thanks all very helpful! The battery was reading 13+ volts off the inside volt meter and with a multimeter directly at the terminals. Water levels were good. Will try grounding the switch better for the LED, but makes sense just to test directly by jacking it up. Will try this tomorrow and let you know how it goes.
Underpowered TV (Video) Bluto Tow Vehicles 5 04-22-2011 09:57 PM
heater seems underpowered davida Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-15-2006 03:52 AM
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 12:57 PM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 11:45 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 04:09 PM
