Old 09-17-2006, 02:00 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Breakaway switch replacement
I want to upgrade my 29 year old breakaway, what brands are good, or are they all the same?
Suggestions
'77 Sovereign Intl 31' CB
Old 09-17-2006, 02:07 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Lipets,
They are all essentially the same. Sort of like engine oil......pick one you like for what ever reason. I would stay with the major brands like Reese or Takonsha.
Old 09-17-2006, 02:42 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
It's hard to go wrong with Bargman. They've been in business for decades. This is available at our fleet stores and most RV dealers. Installation is very simple. This is one I put on my Argosy -- and the same switch is OEM on my Safari.
Name:	Bargman switch.jpg
5 meter Langford Nahanni
Old 09-17-2006, 03:19 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Ok thank you both!
Old 09-17-2006, 07:10 PM   #5
The frame received POR-15 treatment. Then I caulked the hole with Sikaflex 221 before I drove a SS screw to mount the Bargman.
Old 12-03-2006, 07:59 PM   #6
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
My breakaway switch was missing, does the yellow wire hook to it? How does it hook up?
1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
cookeville34 is offline   Reply With Quote
Old 12-03-2006, 08:09 PM   #7
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I seem to be replacing my break away (Tekonsha) every couple of years. I pull the pin just to make sure it will come out, and either the contacts are all corroded or the plastic mounts that hold the spring loaded contacts break off as if they became brittle from heat/sunlight. I'm considering changing to the chrome barrel style that was standard equipment on vintage models and uses a brass pin.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Who are we? FrankR Our Community 105 09-01-2011 01:39 PM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
