Old 04-29-2006, 07:24 AM   #15
Images: 59
Lew,
Thanks for the info. The breaker that Airstream uses is a Type 2 reset. That's a non-cycling type.
markdoane is online now   Reply With Quote
Old 04-29-2006, 12:18 PM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by markdoane
Lew,
No Charge!
Old 04-29-2006, 07:22 PM   #17
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Per a post by Andy with Inland RV pulling the pin will cause damage to the brakes in a matter of seconds.
Silver 67
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 04-30-2006, 01:01 AM   #18
1992 34' Limited
Falls Church , Virginia
Godzilla beat Mothra!!
Beth -
No need to take 'statements' completely literaly.
'Dose of salt' 'might' 'apply'....
Axel
SilverToy is offline   Reply With Quote
Old 04-30-2006, 07:31 AM   #19
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
beth and axel,
andy's comment about damage to brakes specially applies to older trailers with the very small spindles.
the heat from the brakes can detemper the spindles causing them to fail.
modern trailers with larger spindles are not as likely to be damaged...that's not to say it couldn't happen.
john
you call them ferrets, i call them weasels.
Old 04-30-2006, 10:00 AM   #20
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
So how about new ones with disc brakes and the "power pack" hydraulic pump? The instruction tell you to pull the pin before each trip (I think) to check the function of the switch.
Michelle TAC MT-0
Sarah, Snowball
Old 05-01-2006, 05:14 PM   #21
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You can pull the pin to check the operation. Leaving the pin out for a long period of time could cause damage.
I would suggest pulling the pin and checking the operation and reinserting the pin. If you have someone by an axleto listen for any kind of noise the operation would take a few seconds.
>>>>>>>>>>>>>>>Action
Old 05-02-2006, 09:07 PM   #22
hookedonclassic's Avatar
Fond du Lac , Wisconsin
I have a further question regarding the breakaway switch. (I don't know if a new thread should have been created or not.) Anyway, my breakaway cable is threaded through one of the chains and attached to the hook at the end of the chain which attaches to the TV. I don't know if it came from the factory that way or not (2006 model). I don't know if the breakaway switch should be pulled in the event the trailer comes totally disconnected from the TV or when the safety chains are keeping the trailer from coming totally disconnected. The way I have the breakaway switch cable connected, the breakaway would only work when the trailer is totally disconnected. To me, it seems like you would want the breakaway to activate the brakes either way. Your thoughts. I also ready in another thread the length of the chains should keep the tongue from hitting the road if disconnected. Sorry for getting off the subject.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 05-02-2006, 09:23 PM   #23
Reading other posts I may have found the answers I was looking for. Chains should keep the trailer tongue from dragging and breakaway switch should be activated if that happens.
Rich
www.compassion.com
Old 05-02-2006, 10:38 PM   #24
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
rich
your breakaway should be attached to a part of the truck that cannot fall off in the event of the towing system failing, including the whole reciever assembly failing off.
i thread mine around the bumper on my truck through the area around the license plate.
that way, the whole works can come apart and the pin will still get pulled.
john
Old 05-02-2006, 11:48 PM   #25
1992 34' Limited
An 'eye' hook next to the plate....
Hello all -
When I had my recent 'new Break-away switch' adventure I went ahead and remounted it correctly.
Previously it was mounted under the tongue (with ability to swivel) but that seemed restictive if the trailer should happen to come unhitched - VERY UN-linear physics. My thinking was that the pin should be a straight pull out, not an 'off on a tangent of the BAS line'. Overthinking again!?
So I remounted the switch on the top of the tongue with an offset bracket on the Tongue jack mounting bolt - again with swivel ability. I also mounted an ''eye hook" on a straight line with the BAS. I drilled a small hole in the bumper right next to the licence plate on the same side the the BAS. Double nutted the bugger. Done.
Now, when it comes time to hitch SilverToy, I will likely double over the cable, through the 'eye hook',and reattach to the BAS with the same attachment as before. MUCH less play and give than before, ONLY NOW it is guarenteed to pull out straight as SOON as the trailer becomes unhooked for any reason - assuming forward motion. Chains and all that will be stressed but then she should stop ASAP!
HOPING NEVER TO NEED THIS, but it never hurts to be overly cautious.
Hope I am describing this OK for everyone! Let me know if clarifications are needed. BTW - the 'eye hook' looks very purposefull and matter of fact - not ugly as I thought it might. Compliments the 'AIR' sticker on the window very nicely...!
AirStream Forums RULE!!
Axel
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
