Old 11-13-2008, 11:30 AM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Breakaway-How to?
I found the wires to the breakaway switch coiled under the tongue, and not connected to anything. How do I connect to +12 volts? At the voltage to the tongue jack? Do I splice into the brake wire? Maybe the wires are long enough to go up into the front interior to the fuse block?
Thanks in advance.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 11-13-2008, 11:38 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes, and yes.
Old 11-13-2008, 12:03 PM   #3
Ok. Thanks Terry. Now I have my thinking cap on. The PO probably dis-connected it because of failure. I am going to look closely at the switch before I re-attach. Maybe I am better off to replace it, unless I can determine it is new, and never hooked up by PO. (I have only owned this AS a short time, and still going over stuff, before taking it on the road). Thanks again.
Roger
Air# 29488
Old 11-13-2008, 12:20 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
As long as the fuse for the jack is at least 20 amps you can splice one side of the brake away switch to that. The other side goes to the trailer brake wire.
Are you saying the switch was never connected or was connected and broke off. If the latter you should find 2 more wires under the tongue one of which will have 12 volts on it.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 11-13-2008, 12:50 PM   #5
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
The break away switch can be a problem to trailer brakes when it is NOT functioning properly. Make sure it is a good switch before spending a lot of time on reconnecting it.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-13-2008, 02:47 PM   #6
I thank you all for the help. Further investigation, I found the trailer wiring has been modified for the new style connecter. Results are:
1. No breakaway switch connected, but tests good w/ohmmeter.
2. Wire from +12 volts in trailer not connected to tow vehicle.
3. backup wire connected to +12 volts from tow vehicle, backup bulbs removed.
4. yellow brake wire connected to backup light at tv connector, then yellow wire dis-connected from brakes. New blue brake wire run under trailer from connector.
I will fix this mess before the AS is on the road.
Thanks again for the help.
Roger
Air# 29488
Old 11-13-2008, 03:34 PM   #7
HowieE's Avatar
Images: 12
Did you just buy this trailer and did someone have it on the road before that?
2004 Excursion 4x4
Old 11-13-2008, 07:38 PM   #8
Yes, this trailer was used by someone from another state, Utah or Idaho, I think. They traded it for a newer airstream in Quartzsite. I bought it from the dealer here in central california. In addition to the things I just listed, I found three of the four brakes inoperable due to broken ground wires, two of the brakes shoes badly burned and cracked. Needless to say, the 60 miles I towed it to my home were probably the worst from a safety point I hope to make with this trailer.
Thanks to all for the responses.
Roger
Air# 29488
Old 11-14-2008, 05:11 AM   #9
Dan@LED4RV's Avatar
Denton , North Carolina
no
fuse block
No, the brake-a-way switch is not fused at all. It is a emergancy system to stop the trailer if it gets away from the tow unit. If it is fused, and the fuse blows, then no power will be going to the brakes.
For those who may not be sure what a break-a-way looks like
Click here to see what a Brake-a-way switch looks like.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Breakaway Device HansenClan Brakes & Brake Controllers 21 08-24-2008 04:50 PM
Breakaway switch. FreshAir Brakes & Brake Controllers 44 02-12-2007 11:18 AM
Breakaway Switch PunkZTT Brakes & Brake Controllers 24 05-02-2006 11:48 PM
breakaway switch aeriqua Brakes & Brake Controllers 2 01-09-2006 06:48 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
