Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-10-2005, 04:10 PM   #1
CACTUS
Profile:
"BREAKAWAY BRAKES"
Got stuck in the mud and head to disconnect truck to get out. I left the trailer in the mud until the next day. When I went back to get the trailer with a monster truck I found the reason I got stuck in the first place. The breakaway
cable got pulled out and applied power to brakes. Question I can't take wheels off for at least another month, and I can't sleep thinking I damaged the brakes,
what our my chances they are ok? My batteries were completely dead.
CACTUS is offline   Reply With Quote
Old 01-10-2005, 04:18 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
The brake linings will be fine.
Unfortunately, the brake magnets & wheel bearings may have been damaged by the heat of the brake magnets after multiple batteries were drained.
I hope you did not have to tow it far after getting it unstuck.
Tom
Old 01-10-2005, 06:02 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
It can't be accurately predicted. Each magnet consumes as much energy (and heat) as a 40 watt light bulb. If the drums were buried in mud, I'm sure they got pretty hot!
Non-contributing deadbeat.
Old 01-10-2005, 06:29 PM   #4
wayner1239
Profile:
My breakaway switch was accidentally activated while the trailer was parked. It drained the battery. I pulled the drums and inspected the magnets but did not see any damage. The brakes work great. I guess I was lucky and hope that you are too.
Wayne
wayner1239 is offline   Reply With Quote
