Old 06-30-2015, 05:49 PM   #1
1972 31' Sovereign
Lake , Michigan
Breakaway
Can someone please post a picture of the breakaway. I believe the previous owner cut the wires and we are trying to figure out how to hook it up.
Thank you
Lesbill is offline   Reply With Quote
Old 06-30-2015, 05:57 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
One side of the switch goes to the trailer battery positive terminal with a 20 amp fuse in that line. The other side is connected to the trailer brake wire.
If the pin is pulled out of the switch full battery voltage is applied to the trailer brakes.
2004 Excursion 4x4
Old 06-30-2015, 06:27 PM   #3
1972 31' Sovereign
Lake , Michigan
Wires
Trying to send a pic but no luck what we have are five wires, one loose the other four wire nutted two together
Old 06-30-2015, 07:10 PM   #4
1972 31' Sovereign
Lake , Michigan
Old 06-30-2015, 07:22 PM   #5
Sioux Falls , South Dakota
Can you follow the wires? Do you have brakes on both axles or just one?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 06-30-2015, 07:44 PM   #6
1972 31' Sovereign
Lake , Michigan
Two black from cylinder breakaway,one loose,one wire nutted to gray/white coming from tongue,
One gray/white from top of jack nutted to red coming from tongue
I believe two brakes
Old 06-30-2015, 09:06 PM   #7
HowieE's Avatar
Images: 12
The wire nutted to the red wire is the jack power and should have a 30 amp circuit breaker between the wire not and the battery.
The 2 black wires are the breakaway wires. Test the one that is wire nutted for voltage on it. If it does not have voltage on it it most likely goes to the breaks. If it has voltage the other wire, currently loose, can be connected to it to supply power to the switch.
2004 Excursion 4x4
Old 07-03-2015, 12:30 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That brake a way switch looks like it has seen better days.
>>>>>>>Action
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 11:57 AM
"BREAKAWAY BRAKES" CACTUS Brakes & Brake Controllers 3 01-10-2005 05:29 PM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 10:45 AM
Trailer breakaway cable wayner1239 Brakes & Brake Controllers 47 12-08-2003 06:13 PM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
