The last time I parked the Airstream and unhooked it, the safety brake wire got caught on the hitch when I pulled the truck away. Needless to say, the wire broke. I can fix the wire with no problem.
My questions is did this lock up the brakes on the Airstream? Do I need to have the brake system checked for any damage?
Kathy
Chattanooga, TN
Air #2757
It's Time To Rally!
Falluminum '08 - Georgia Mountain Fairgrounds
Hiawassee, GA
November 7-9, 2008
Reason: Split thread
If the wire pulled out of the breakaway switch and activated the brakes, the answer is yes, if the brakes were on full power for more than 5 minutes.
If it was a clean break in the wire and the brakes did not come on, you should be able to just fix the wire.
