Old 08-06-2014, 12:58 PM   #1
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Braking Weak
During the last two pulls of our 30' Classic, the trailer brakes have seemed to be weak. I use the Tekonsha Voyager brake controller and the indicator light does not go as red as it used to during braking.
Last night I jacked up one side of the trailer and pulled the emergency brake actuator pin. I attempted to turn the wheels by hand and the rear one locked up so I could not move it; the front wheel was difficult, but never locked up completely.
Wondering if my magnets need replacing.
Comments??
Thanks all!
10Smiles is offline   Reply With Quote
Old 08-06-2014, 01:34 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like a brake inspection and adjustment may be in order. Do you adjust the brakes periodically?
Old 08-06-2014, 07:05 PM   #3
10Smiles's Avatar
2005 30' Classic
Good question, it could just be the adjustment. I checked the adjustment just over a year ago when I installed new wheels/tires. I will do an inspection.
Thanks for the idea (in this day and age, I forget about manually adjusting brakes).
Old 08-18-2014, 01:19 PM   #4
10Smiles's Avatar
2005 30' Classic
OK, I have performed the manual adjustment of the brakes on one side of the trailer. First I jacked up the trailer (Port side) and spun the wheels and they were free.
I then pulled the emergency brake actuator; the wheels continued to be able to spin freely. I am now confused, so I pulled the wheels and brake drums. The magnets are worn looking. Not sure if there is a specification for how worn they should be allowed to be. Anyway, I pulled the emergency brake actuator again and tested the magnets with a screw driver; the magnets are being energized. My guess is that they are worn enough so they do not contact the drum and, therefore, actuate the brakes.
So, I put it back together and adjusted the brakes. The brake linings are getting thin, so I need new linings as well, so I am in the process of selecting fully assembled backing plates as replacements.
Do I need to get new drums too?? Or I can get the old ones turned.
Regards,
David
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Help! need info on weak spot in front floor. Venpetra Repairing/Replacing Floor &/or Frame 3 09-21-2007 06:57 PM
Power problem indicated by "weak" microwave? davida Batteries, Univolts, Converters & Inverters 4 06-12-2007 01:23 PM
Cool air, weak fan? RedSHED Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-31-2007 08:17 AM
Weak wall Pahaska 2002 - 2005 International 4 12-01-2002 09:00 PM
