Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-04-2007, 09:01 AM   #1
Mookie's Avatar
1992 21' Sovereign
Oakland , California
Images: 60
Brakes on Passenger Side Not Working - Please Help
I was doing general maintenance, getting ready for a road trip, and I noticed that neither of the brakes on the passenger side (tandem axles) are functioning. I can clearly hear the magnets engaging on both of the left wheels but nothing on the right side. Measured the temperature after a road test and both of the wheels on the left side measured 170 degrees but the right side only 70 degrees. I spun the wheels on both sides - left side stops, right side keeps spinning when brakes are applied. I replaced all of my brake backing plates about 2 years ago and was very careful to solder and heavily insulate all connections. Yesterday, I checked all of the wiring that I can see looking for obvious problems but everything looks in order. I've read on the forums that the brake wiring travels down the left side to each wheel and over the axle to the right side. That makes this problem seem especially strange to me since both left wheels are working properly and no power seems to be getting to the right side.
Has anyone experienced a problem like this? I would appreciate any help you can provide.
Thanks!
-Mark
Mookie is offline   Reply With Quote
Old 11-04-2007, 09:15 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Dirty hands
Thanks!
-Mark
Hi Mark, Do you have a stab light or a volt meter? Start back at the wires that enter the drums and see if your getting power and work your way to the tongue. There is an open in the wiring somewhere. Make sure you have a good ground for the testing equipment. Since you know that the left side is working get reading off that side so you know what to expect on the right.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-04-2007, 10:24 AM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The powerline to the curbside is broken. look for the break.
Excella CM is offline   Reply With Quote
Old 11-04-2007, 10:56 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes the wireing is down the drivers side and then cross to the passangers side but the crossover is up inside the bellypan not inside the axles. That makes it a bit hard to trace.
If you can drop the edge of one of the belly pan panels just forward of the front axle you might be able to see the connection to the passanger side. If you do not want to drop a panel consider running a new wire from the tongue toeach of the passanger side brakes. wires that I run under the trailer I run inside 1/8 in tubing for protection.
If you run new wiring consider installing a 10 amp fuse on each side if you have 2 axles. Magnets draw about 3 1/2 amps per so 10 amps is a good choise. This is especially a good idea if you do in fact have a broken wire in the body that you have not located and capped off as it may short in the future and cause you to loose all brakes.
2004 Excursion 4x4
Old 11-04-2007, 05:45 PM   #5
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Check the wires at the wheel that is the most common place for a break. A break is hard to find but easy to fix once found.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
what is this passenger front side glass worth? RichardT Airstream Motorhome Forums 7 04-08-2009 10:19 PM
Help!! Disc brakes aren't working!! sequoiacoast Brakes & Brake Controllers 85 09-26-2007 09:55 AM
Electric Brakes - Are they working? bevman Brakes & Brake Controllers 12 08-25-2007 02:47 PM
Passenger Side lights not working GKurtz Lights - Interior & Exterior 3 07-03-2007 07:40 PM
