Old 06-02-2019, 11:28 AM   #1
Bbelk's Avatar
2010 27' FB Classic
Brakes on a 2010 27fb Classic
I have Drum breaks that donít seem to work as well as they once did.
How long do the shoes last?
Can they be adjusted and is the process the same as old automotive drum brakes?
Is there some other maintenance requirement?
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 06-02-2019, 12:10 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Does your axle have manual or self adjusting brakes? Might be in owners manual or on Dexter label on front side of axle tube.
If manual adj then very similar to old school drums. The self adjuster should do it but they can be adj if reqd but slight different procedure.
Which one do you have ?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-02-2019, 02:20 PM   #3
Bbelk's Avatar
2010 27' FB Classic
I have a Dexter 1589714. There is 40 to 50K miles on them. My pictures donít seem to be working.
2010 27FB Classic
Old 06-02-2019, 02:41 PM   #4
GCinSC2's Avatar
Brad,
I searched the Dexter number and can't tell if that's manual or self adj. by that number.
This was a never lube and self adjusting rig I worked on
http://www.airforums.com/forums/f439...-r-194437.html
Gary
S/OS #001
Old 06-03-2019, 06:42 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If you have not pulled a drum in two years or more, now would be a good time for that.
Before the drum is pulled and after the tire/wheel assy is removed spin the drum. A good adjustment would have the friction material touching the drum ever so slightly.
Many of these are NOT self adjusting. To answer your question, YES adjusting them would be like adjusting rear brakes on much older cars.
>>>>>>>>>>>>>>>>Action
Action is online now   Reply With Quote
Buying a 2010 Classic 27FB ... Maybe bachmannfive 2006 - 2010 Classic (all lengths) 3 06-15-2019 10:07 PM
Headboard removal 2010 27FB Classic Bbelk Upholstery, Blinds, Walls & Interior Finishes 1 12-31-2016 03:05 PM
1Owner 2010 Airstream Classic Limited 27FB Front Bedroom Hickory Corian 3awnings eBay Watch Airstreams on eBay 0 05-15-2012 10:00 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
