Old 10-12-2016, 07:32 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Brakes not working on new axle-- Help!!!
Finished putting in a new axle on my 1980 Caravelle. Took it for a test run and the brakes are Not working
There is a noise coming from the brake drum when I put down the brake pedal, so it sounds like it is getting juice.I'll get the amp meter out in the morning. What should I look for? Need to have brakes for these mountain passes in Montana! Any help would be greatly appreciated! Don
glacierrunne is offline   Reply With Quote
Old 10-12-2016, 07:58 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Did you adjust them so there is a slight drag when you spin the wheel?
Also, when I installed my new axles, it took a good many stops to get the brake shoes and the drum mated to each other. After that no problem but at first I was not getting much braking even with the shoes adjusted.
Good luck.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-12-2016, 08:37 PM   #3
1991 25' Excella
Stanfield , Oregon
Brakes need to be broke in when they are new and they also need to be adjusted. Are you new axles equipped with self adjusting brakes? If so they well get better if not then you well need to manually adjust them.
SpletKay06 is offline   Reply With Quote
Old 10-13-2016, 07:57 AM   #4
1980 20' Caravelle
Yes, I paid the extra and got self adjusting brakes but surprised no drag at all when depressing brake pedal !
Old 10-13-2016, 08:21 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I think that the self adjusting feature only works when applying the brakes in reverse.
Typically new axles come with the brakes way backed off and should be adjusted manually the first time.
You may be able to adjust the brakes by manually applying the brakes many times while backing. It may take A LOT of applications to bring the brakes into spec.
Gradiens super tenui glacie.
Edit- I know for a fact that hydraulic drum brakes only adjust when backing in reverse, I have no experience with self adjusting electric brakes, but I am assuming a similar function.
Old 10-13-2016, 12:26 PM   #6
1959 24' Tradewind
Twin Falls , Idaho
From watching the attached video there needs to be some drag when the wheel is off the ground. If not you need to adjust, start watching at 11:30. Trailer brake controller?
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 10-13-2016, 12:29 PM   #7
1996 25' Excella
Tillsonburg , Ontario
I always adjust brakes tight enough to prevent turning the hub manually then back off about 6- 8 notches on the adjusting wheel. It is a lot easier to adjust brakes with the wheel off but not necessary.
Anyone else have an opinion on this?
JCW
JCWDCW is offline   Reply With Quote
Old 10-13-2016, 12:37 PM   #8
Gainesville , Florida
Do you have a brake controller? Without one, no brakes. If you have one, is it adjusted properly.
Old 10-13-2016, 12:38 PM   #9
1967 26' Overlander
Spartanburg , South Carolina
Before you do anything, make sure the brake shoes are adjusted properly to the drum. Then make sure the brakes are getting power by pulling the break-away switch. You should hear the brake magnets engage. If so, set the gain on the brake controller to max. and drive slowly forward a few feet and press the brake pedal. With new brake shoes and drums you should feel a slight drag.
When I changed axles on my '67 Overlander with the new drums AND shoes I could barely sense the brakes were engaging at first even with max gain, but driving slowly for about 20 miles on back roads and applying the brakes often after accererating each time, I gradually got more brake action.
I don't know why but the new brake drums just don't seem quite as good as my old ones. I do have adequate stopping power with more gain on the controller. Just so you know, I use the vintage Kelsey-Hayes hydraulic/electric system.
BTW what kind of axle did you install? When I researched mine, I found that the stock axle to match original did not have the same diameter brakes. For some reason during the intervening years, axle mfrs changed from 12" to 10" brakes on the original size axle. According to my conversations with other vintage owners who had experience with them, 10" brakes have 10 to 20% less braking power compared to the original 12" brakes.
Jacob D is offline   Reply With Quote
Old 10-13-2016, 03:25 PM   #10
1991 25' Excella
Stanfield , Oregon
Self adjusting trailer brakes adjust when going forward or backward it doesn't matter which direction there moving. They work differently than automotive brakes.
Old 12-23-2016, 02:16 PM   #11
1980 20' Caravelle
brake adjustment
I manually adjusted the brakes--wish it would have said that in the instruction sheet!!! I did NOT want to brake them in, driving in the mountains on the first trip. Thanks to all the comments!! Don
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
New Electric Brakes not working on 64 Overlander 64Overlander Brakes & Brake Controllers 0 06-23-2009 08:21 AM
Brakes on Passenger Side Not Working - Please Help Mookie Brakes & Brake Controllers 4 11-04-2007 05:45 PM
