Old 12-16-2008, 07:48 AM   #1
funkill's Avatar
reno , NV
Images: 27
brakes lock-up initially
Question about my braking system....
Whenever I hook up and head out, I notice that my trailer brakes are very *sensitive* for the first 500 yards or so ... that is, when I just barely touch the brake pedal on my truck, the trailer brakes lock-up. I usually get out of the truck - walk around it just to check things out - and start again. Seems that the brakes are okay after that. My neighbor explained that it's due to backing in and the brakes being *set* differently. BUT, I noticed this happens regardless of whether my last movement was backing into a space or just pulling forward and stopping for the night. I have a Tekonsha Voyager brake controller. Any ideas?
Laura
funkill is offline   Reply With Quote
Old 12-16-2008, 07:53 AM   #2
Laura
The cause is rapid rusting of the drums, because of the location of the trailer.
Overnight rusting can occur, so that when you first hit the brakes a few times, the "extra" braking comes from burning the rust off. After a few brake applications, the rust is gone, no more problem.
There is no cure other than get away from the salt water.
Old 12-16-2008, 09:10 AM   #3
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
I live in a desert climate so what Andy said doesn't apply to me. Never-the-less, I have severe brakes for the first few applications. I don't worry about it. By the way, I live on the side of a mountain and the first few applications are on a steep downgrade.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 12-16-2008, 09:21 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you want to reduce this before you get out in traffic.
As you pull out do so with the manual brake controller on just a little so you are actually pulling against the brakes. You shouldn't have to do this for more than 100 ft. This will clear the rust off the drums.
I am assuming you have checked your brake shoes recently and are not down to rivets or metal.
2004 Excursion 4x4
Old 12-16-2008, 10:15 AM   #5
funkill's Avatar
reno , NV
Images: 27
Thanks for the replies! You've answered my *curiosity* about this condition!!! The PO said the brakes were *good* --- and I've put on about 500+ miles. But - will be getting new brakes with my new axles. Planned installation date of 12/21/08!!!!
Older style trailer brakes lock up in reverse whitefawn Brakes & Brake Controllers 15 08-01-2012 06:37 AM
how does this lock go together? BGS Doors & Locks 0 05-01-2008 02:42 PM
lock-up brakes from overnight dampness... safari25-05 Brakes & Brake Controllers 13 02-04-2007 07:47 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
