Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 06-30-2008, 06:09 PM   #1
bluegrass-girl
Profile:
Smile Brakes-Have tried most everything.
My trailer brakes in 28', '99 Airstream Excella do not apply firmly. Regardless of the Prodigy controller setting, when I test them by operating the controller lever I drift very slowly to a stop.
I have replaced the controller. We thought there might be a problem with it - the Prodigy tech rep said to replace it under warranty. Changing controllers did not help.
The output at the controller is 13.6V, 5.5Amps. The readings at each of the brake magnets is 10.6V, 3.8Amps (with controller set at full gain of 13). These magnet readings are within the specs listed in the Airstream manual. When I test the breakaway switch, the trailer brakes are locked at a standstill.
The trailer never had a great deal of use. The brake linings and the drums are in very good condition. There is no shiny glaze on the linings. They are smooth and even.
I have used a corrosion block to free up the movement of the mechanical brake shoe components so that all work smoothly.
I have applied a straight edge to the lengthwise dimension of the magnets. They have not worn unevenly at one end. However, they are somewhat rippled on the wear face, and a similar uneven wear is on the surface of the drums. I asked a very experienced Airstream mechanic about this, and he stated that he sees this condition sometimes. His opinion is that if these grooves are fairly minor it should be okay. I would say that two of the magnets have very little - but some - uneven wear. The other two are definately rippled.
Other than the voltage and amperage loss at the magnets, the uneven face of the magnets is the only thing I can find.
Mind you, I was an accountant by training. I'm not great at mechanical stuff.
Is my ONLY next step to replace the magnets and have the drums resurfaced? Do most machine shops have the capability to do this resurfacing work?
Help would be greatly appreciated. Steve
Bluegrass Girl
bluegrass-girl is offline   Reply With Quote
Old 06-30-2008, 07:13 PM   #2
JackMac
Profile:  1999 25' Safari
Fairburn , Georgia
Are the shoes adjusted to the drums properly?
JackMac is offline   Reply With Quote
Old 06-30-2008, 07:23 PM   #3
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Please define "firmly". Electric brakes do not have the braking force of hydraulic or disc brakes. Don't expect the trailer brakes to lock up. A gradual stop if you are using the controller only may not be unusual. Remember you are then using the trailer brakes to stop both the trailer and TV. The amperage going into the brakes sounds like it is right on the money.
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 06-30-2008, 07:57 PM   #4
bluegrass-girl
Profile:
The brakes were adjusted recently by a mechanic who frequently inspects and works on heavy trailers. I then had the trailer at an Airstream dealer a month ago, and they changed the brake adjustment slightly. They were aware that I was having problems with braking efficiency.
During the time that I have owned the trailer, I have followed the Prodigy directions in setting the controller. Find the point at which the brakes just lock up, and then back back off on the gain very slightly. Up until recently, I could lock up the trailer brakes if so desired in a road test at 25 mph. I can set the gain all the way to 13 and the best I can do is slow the truck/trailer down slowly with the trailer brakes. The trailer brakes should stop the truck and trailer in a 25 mph test.
Thanks, Steve
Bluegrass Girl
Old 06-30-2008, 08:13 PM   #5
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Brake Problems
Try this and let me know what you get.
Get a long piece of wire, #16 lamp cord will work.
You will need access to a brake magnet +12 Volt supply wire.
Connect the trailer to the tow vehicle and plug in the trailer plug to the
tow vehicle.
1. Measure the output voltage of the Tow Vehicle (TV) battery. It should be around 13 Volts DC. Write this value down.
2. Clip an alligator clip wire to a bare brake wire at the wheel.
3. Run the wire alligator clip wire to the TV.
4. Clip the end at the tow vehicle to the negative lead of your volt meter.
5. Connect the POSITIVE lead to the + output terminal of your brake controller.
6. Turn the Ignition Switch of the TV to the ON position.
7. Fully depress the panic stop button on the Brake controller. While holding the button fully depressed and the volt meter still hooked up to the + lead on the battery and the brake wire read the voltage. It should be close. Release the panic stop button. Turn off the ignition switch.
If the voltage is not close (within a volt) we will make more measurements.
8. Remove the positive lead from the Brake controller
9. Gain access to the back of the trailer plug mounted on the tow vehicle.
10. Connect the positive lead of the volt meter to the brake wire coming from the controller (on the TV side of the trailer plug).
11. Have a friend:
A. Turn on the Ignition Switch.
B. Depress the Panic stop button.
12. Read and write down the voltage. This voltage should read less than .5 volts.
13. Turn off the Ignition Switch
If it does not read this low, you have high resistance somewhere between the plug and the brakes, which is what I suspect. The resistance that I am referring to is so low you may not be able to measure it with your ohm meter, so you measure the voltage developed across it.
You measured 13.6 volts at the back of your brake controller. You measured 10.6 volts at the brake magnet. Doing the math there is approximately .5 ohms resistance caused by a bad connection probably.
14. Gain access to the trailer Plug cord (the one that connects to the TV) in the trailer.
15. Connect the + lead of the meter (other end still connected to the brake magnet wire) to the brake wire at the end of the trailer cord on the trailer.
16. Again have you assistant turn on the TV Ignition Switch and depress the Panic switch fully.
17. Read and record the voltage.
18. Turn off the TV Ignition Switch.
19. Voltage .5 volts or less? If so you have a problem somewhere between where your + meter lead is connected in the trailer and the back of the truck (female) plug.
20. Scratch clean a piece of metal on the TV. Place the + meter lead on this clean spot
21. Have your Assistant turn on the Ignition Switch and depress the Panic Button.
22 If you read .5 volts or less then the problem is in the +12 volt brake wire going to the brake magnets somewhere between where you measured the voltage in step 17.
23. Turn off the Ignition Switch.
If you read more (especially 3 volts) the problem is a bad ground, usually in the trailer plug and cord or where the ground wire from the trailer plug receptacle on the tow vehicle is connected to ground or in the plug itself. The easiest thing to do first is clean the ground spot where the ground wire is connected to the frame of the TV.
Next clean the spot on the Trailer where the ground wire is connected to the trailer frame.
Hope this helps.
Beginner
Beginner is offline   Reply With Quote
Old 06-30-2008, 08:24 PM   #6
Rebee
Profile:  2007 30' Classic
Leonardtown , Maryland
This is a stupid question but I have to ask. Is the prodigy set on B1, B2 or B3? It should be on B3.
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 06-30-2008, 08:40 PM   #7
KeithC
Profile:  1968 24' Tradewind
Mansfield , Georgia
Hey bluegrass-girl,
From your posting I could tell you take your Airstream braking system as seriously as I take mine. I think is a safety matter not to be patched or half-assed engineered because I love my Vintage Airstream, but I love the people riding in the tow vehicle attached to the trailer much more.
I'm not an Airstream brake guru, so please do not take my observations as someone of authority that knows all about Airstream brake systems, because I do not.
I did noted the tech. spec. details of your posting and wondered..why the Volt /Amp. loss was so great in such a short wire run from the controller to the brake magnets? That loss could only occurr if there was a short / partial short.
I had a sim.problem with my Airstream TT. What I experienced with my 1968 Tradewind TT was an unexplained loss of braking power with no common causal factor that I could reproduce static. After many attempts, I was getting really annoyed.
I tried and tried to reproduct the factors that caused the brakes to fail or to partially work without finding the common cause.
Long story short, a previous owner had dropped the belly skin and stray foamed the entire underside of the trailer, including the brake wiring and junction points. The spray foam had trapped mositure and corroded the wiring. Shorts developed, on and off, as the trailer moved and twisted.
To test this theory in application a dedicated wire run was made from the tow vehicle wiring harness to the brake system wiring drums.
Poof..the Airstream trailer electrical brakes activated and locked up and a 3/4 ton diesel turbo tow vehicle just spun it's wheels trying to move it.
As an ecomonic choice, rather than remove all the spray foam and replace the wiring and junction points above the belly pan, a new brake wire was run through a PVC conduit attached to the outside of the trailer's frame to the brake system.
Total cost for materials was approximately $25.
Just something to think about and test.
I hope it helps,
keithc
KeithC is offline   Reply With Quote
Old 06-30-2008, 09:03 PM   #8
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I just scanned through this, and didn't see it posted, but check to see if the magnets or magnet contact areas are covered in brake dust or grease.
Old 06-30-2008, 09:04 PM   #9
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
From your description it sounds like the braking efficiency has degraded from a formerly adequate performance level. If so, then you must have developed a poor connection somewhere along the circuit. Remember that the ground return is as important as the wiring out to the magnets. You'll need to do some sleuthing to find the problem. Look at any/all connectors and especially the umbilical plugs at both ends. signs of discoloration due to heating are a good clue to high resistance.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-30-2008, 09:10 PM   #10
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
Excellent description of the problem, bluegrassgirl, in terms of what has been checked thus far. You may not be "trained" in these mechanical arts, but your ability in description is EXACTLY the way to look at RV systems, be they mechanical, electrical, gas, fluid and/or combinations. A systematic approach works wonders once one gets the hang of it, one then is "ready" to consider, test and eliminate. You're more than half-way to the solution with this sort of approach. A cluster of details to attend, your training was ideal.
Good luck.
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 06-30-2008, 10:10 PM   #11
bluegrass-girl
Profile:
I have received some excellent suggestions. I'll continue to search for electrical problems tomorrow.
For your information, the tow vehicle is a heavy, 2003 Chevy 2500 diesel with Allison transmission. It weighs nearly as much as the trailer. I have used a Prodigy setting of B1 in the past with excellent results. In the tests over the last several days, I switched to B2 with no discernable improvement. I'll try the B3 setting.
I thoroughly cleaned the surface of the magnets. There was a fair amount of brake dust on the shoes and drums. All has been cleaned.
The direction that the comments seem to be taking is to look at the considerable voltage and amperage loss between the controller and the magnets, to include possible ground problems. This is just the kind of steering that I need.
Thanks, Steve
Bluegrass Girl
Old 06-30-2008, 10:39 PM   #12
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
You might want to check the 7 pin connectors for corrosion as well. If something was going to change in the electrical circuit, that would be the most likely place.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 07-01-2008, 10:16 AM   #13
rogerdodger
rogerdodger's Avatar
Profile:  1981 27' Excella II
clovis , California
When I checked my brakes, I found 3 of the four magnet ground wires broken, PO had not allowed long enough wire when axles moved up and down, so make sure you have a god ground to each magnet. Just my $.02.
Roger
Air# 29488
WBCCI# 2582
W6ROG
TV-2005 Dodge Durango Hemi
rogerdodger is offline   Reply With Quote
Old 07-01-2008, 06:33 PM   #14
Beginner
Norfolk , Virginia
Images: 11
Brakes
Indeed
You are losing three volts somewhere.
It could be caused by almost broken wire, corrosion at the plug contacts,
corrosion where the wire goes into the back of the contact or a bad ground. The resistance is so low that you cannot measure it reliably with a regular volt meter, so look for voltage developed across it.
Beginner
brakes KeithC Brakes & Brake Controllers 8 09-21-2007 11:00 PM
The brakes. jcferguson Brakes & Brake Controllers 3 02-26-2006 08:28 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 10:18 AM
No Brakes IndyCutter Mechanics Corner - Engines, Transmission & More... 6 01-21-2006 07:43 AM
No Brakes! Please Help? Navigator Brakes & Brake Controllers 3 11-20-2003 02:45 PM
