Old 05-22-2014, 12:36 PM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
Let's look at this. If it were the brake lights and you are drawing 12 amps, 4 magnets at full power, plus the brake lights you would blow the brake light fuse.
Intermittent electrical problems are the hardest to figure out but logic can be applied and many things eliminated. Look to the things that can carry that amount of current and not fail themselves.
2004 Excursion 4x4
Old 05-22-2014, 06:40 PM   #16
1964 24' Tradewind
Lawrence , Kansas
I am really not much of a meter guy but I most likely can check the voltage next time it happens.
It is possible that I nocked the controller to a less level position but it has a lever on the side and it is straight up and down as per instructions.
When the grabbing is not happening every thing works perfectly. The problem has been there about for about 1 1/2 hours total in 8000 miles of towing. While it has always happened at the start of a towing period the interval between the end and start of a towing period have been a matter of hours to up to 3 months. My approach has always been to play with the 7 pin and the controller until it goes away but I have never identified anything I did that made it stop which it always has sooner or later.
I think Howie might be on the right track but I would of thought a controller would either work or not work.
ttbikes is offline   Reply With Quote
Old 05-22-2014, 06:50 PM   #17
HowieE's Avatar
Images: 12
Voltage. The controller output is measured in amps.
What you can measure is the voltage input to the controller. The battery voltage right after starting is low. It takes about 20 miles on the road to bring a battery to full charge.
On my diesel the glow plugs remain on for over minute after starting and the battery voltage is well below 11 volts. If there is a component in the controller that is susceptible to low voltage that may be it.
2004 Excursion 4x4
Old 05-22-2014, 07:07 PM   #18
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
The little trim adjusting lever on the side of the controller has a lot to do with grabbiness if it is occurring when you apply the brakes.. If it is pointing towards front of vehicle from perfectly vertical, it will lead to brakes grabbing.. If it is pointing instead towards rear of vehicle, it will feel like brakes are slow to take effect.. I'd try test drive and move lever towards rear and see if that cures grabbing brakes.. You can then adjust back towards forward until they feel correct.. No meter needed!
Condoluminum
Condoluminum is offline   Reply With Quote
Old 06-11-2014, 07:43 AM   #19
1964 24' Tradewind
Lawrence , Kansas
So I believe I may have fixed the problem and if I am correct it makes me feel a little dumb. My controller (Hayes Energizer III) has a operating range for level (-35 degrees to 90). The controller was knocked off level close to the limit but not over it. I had checked the lever on the side for the correct position and every thing operated normally under normal conditions. However, on steep downhill grades the controller was outside the level operating range just enough to cause the brakes to grab. By far the biggest problem I had was in the Ozarks, but because it was so infrequent, it had me assuming a short. In addition, the first time it happened was starting out on a flat road. I now believe I fixed it the first time by adjusting the lever which made it operational under most conditions. I took the trailer back to the Ozarks this week-end and had no problems. I still may be whistling in the dark, but I hope not. Does this sound possible to you all?
Old 06-11-2014, 09:58 AM   #20
r carl's Avatar
Lin , Ne
Yes, something was powering your brakes once in awhile.
Old 06-13-2014, 12:06 AM   #21
Pileus's Avatar
1985 31' Excella
Seguin , Texas
Yes,
The brake controller itself is sensitive to the angle it is mounted (tilt). If it is tilted up the brakes will grab.
Pileus is offline   Reply With Quote
One out of four grabbing? Chatthayer Brakes & Brake Controllers 7 11-07-2012 06:24 AM
Brakes Grabbing and Noisy Ag'71 Brakes & Brake Controllers 2 09-18-2010 07:56 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
