Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-06-2005, 06:10 PM   #1
garymacf
Profile:
Brakes grab when crossing RR tracks, bumps
Our 1974 Sovereign pulls fine except when we cross railroad tracks or any section of rough road. Then the trailer brakes cycle on and off, which makes for an interesting ride. I'm guessing we have some kind of short. Does anyone have a suggestion for where we should start the troubleshooting? Is there a frame ground location that might be a good starting point? Also, our trailer manual is missing (just under a stack of old National Geographics, I suspect. Does anyone have a source for wiring diagrams that can be downloaded?
Many thanks.
garymacf is offline   Reply With Quote
Old 08-06-2005, 06:41 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Many thanks.
Sounds like you have a 12v + wire that touches a brake power wire when you go over a bump. It is probably in the hitch plug area, that is where most of the powered wires are located. Look for chafed wires in the harness.
It may even be that when you go over a bump, the brake lights come on in the tow vehicle, because of a loose or misadjusted brakelight switch.
Good luck with it.
Old 08-06-2005, 06:53 PM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
What makes you think the brakes are actuating?
I have noticed, through pulling a variety of trailers, that when the axle(s) clear whatever bump in the road presents itself, I feel a certain drag on my tow vehicle due to simply pulling the towed load up a small incline.
FWIW, I know on my JetSki trailer that part of the drag is the tire hitting the improperly mounted fender . Are your axles in good shape?
Tom
Old 08-06-2005, 06:57 PM   #4
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
Could this be caused by an inertial brake controller?
greg176 is offline   Reply With Quote
Old 08-06-2005, 07:04 PM   #5
overlander63
Rivet Masher
L.A. , California
It could, if the brake lights came on. The controller uses the brakelight signal to activate the trailer brakes.
Old 08-08-2005, 02:21 PM   #6
garymacf
Profile:
brakes come on at RR crossings/bumps
I believe the brakes are definitely cycling...I don't think it's bad axles or something hitting the fenders. But for starters I'll have someone follow me while I cross some RR tracks near the house and see if the brake lights are coming on or not. Good suggestion. Thanks.
Gary
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 05:41 PM
