Old 02-26-2008, 04:39 AM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Brakes Fully Loaded - Which Ones
I'm going to install new tires, wheels and shocks this year. Like everything else one job seems to lead to another. Figure while I have the trailer up on ramps new loaded brake plates would be a good idea. We have Henschen axles (original) rated 2600 lbs..
Which of these should I install and will they fit my axles? Would it be a good idea to go up to the 7000 lb. rating or is that just a waste of money. Thanks.
12" x 2" Electric Brake Assembly - Right Hand / 5.2k
Stock# 5331010
12" x 2" Right Hand complete electric brake assembly.
This brake is rated to a maximum capacity of 5200 lbs. per pair.
DEXTER part #023-106-00
ON SALE NOW, Reg. $48.99 $38.99 12" x 2" Electric Brake Assembly - Left Hand / 5.2k
Stock# 5331009
12" x 2" Left Hand complete electric brake assembly.
DEXTER part #023-105-00
ON SALE NOW, Reg. $48.99 $38.99 12" x 2" Electric Brake Assembly - Right Hand / 7k
Stock# 5331056
This brake is rated to a maximum capacity of 7000 lbs. per pair.
DEXTER part #023-181-00
ON SALE NOW, Reg. $69.99 $49.99 12" x 2" Electric Brake Assembly - Left Hand / 7k
Stock# 5331055
DEXTER part #023-180-00
Old 02-26-2008, 04:18 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The difference is only $11 each, as long as the higher rated ones will fit your spindles. The spindle size (where the backing plate bolts on) may be larger on the higher-rated backing plates.
If you think about it, are you going to have 20,000# of stopping to do? Our Sovereign and tow vehicle together weigh less than 15,000, fully loaded.
Old 02-26-2008, 04:28 PM   #3
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I'd rather have more brakes than I need as opposed to having less. JMHO
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 02-26-2008, 05:00 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
well I would go for a disk break set up... if interested let me know and i will explain what it takes to do! I would also get your axil tested... Any thing older than 1980 should be looked at...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Just joined. Fully rebuilding a 1969 Globetrotter Jonz Member Introductions 8 09-17-2007 03:09 PM
1973 Argosy Fully Restored pclois Member Introductions 1 06-28-2007 09:19 AM
Help w/ fully dead bat's RiskIt Batteries, Univolts, Converters & Inverters 18 06-17-2007 07:18 AM
Value....of 1994 Airstream Classic limited....."Immaculate , fully loaded"!!! route66 Off Topic Forum 7 09-22-2004 07:02 PM
Pictures loaded eraffety Airstream Motorhome Forums 18 04-08-2002 10:32 AM
