Old 05-28-2016, 12:55 PM   #1
Bambified's Avatar
1962 16' Bambi
Bunnell , Florida
Brakes for my '62 Bambi
Pulled the drums and I see the Brakes are 10". Lots of corrosion, so I want to replace the entire electric brake assembly. I found these 10" brakes online at Northern Tool. Model #86805. Anybody ever done this? Anybody know if they will fit? I can't find any posts on this.
ID:	263389   Click image for larger version
ID:	263391   Click image for larger version
Bambified is offline   Reply With Quote
Old 05-28-2016, 09:02 PM   #2
Images: 59
I would go ahead and try them, but I think I'm looking at a 64 year old Henschen axle that may not have any "bounce" left.
Old 05-28-2016, 09:04 PM   #3
1991 25' Excella
Stanfield , Oregon
Putting new brakes on a worn out axle is money wasted
SpletKay06 is offline   Reply With Quote
Old 05-28-2016, 10:33 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Judging from the angle of the torsion arm it is time to replace the entire axle. Don't waste your money for new brake assemblies.
Old 05-29-2016, 07:24 AM   #5
Bambified's Avatar
1962 16' Bambi
Bunnell , Florida
New axle
I don't have a reference for what is typically the angle of the trailing torsion arm. We get abut 2 inches of travel when standing on the axle and jumping up and down. If we replace, what axle would be a good fit? Should I convert to a generic leaf spring axle? Does Dexter make an axle that will fit? I'm clueless on this. I would like to keep the 4-lug 13" wheels if possible.
Old 05-29-2016, 10:19 AM   #6
1961 24' Tradewind
1967 26' Overlander
Savannah , Georgia
Contact Colin Hyde. He is the axle guru and can provide an axle for you that will probably bolt on without modification. He is TERRIFIC to work with.
beatrix1 is offline   Reply With Quote
Old 05-29-2016, 11:12 AM   #7
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Three Rivers , California
gotta agree with spletkay06.... as i put on my 59' a new Torflex Dexter Axle complete with electric brakes, drums etc...$1000 but what a difference.
twolanehwy is offline   Reply With Quote
Old 05-29-2016, 12:29 PM   #8
1967 26' Overlander
Spartanburg , South Carolina
Google Dexter Axles to find the dealer nearest you. They will be able to provide you with exact specs and dimensions for all Dexter axles. If you don't want to replace your old axles, a new Dexter assembly already mounted on a backing plate will probably bolt right on as did mine a few years ago.
Someone else suggested Colin Hyde which is another good source of info. He can actually provide the actual axle you need with little or no modification to the frame.
I too recommend you replace the entire axle. The problem with my old axles was not sag but lack of cushion. My '67 rides so much smoother now with new Dexter axles.
Jacob D is offline   Reply With Quote
Old 05-29-2016, 02:29 PM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Bambified
You have torsion axles. It may be difficult to engineer/design a set of leaf springs to install on your trailer. (Change in most of life is a struggle)
With that said the torsion axles you have may be welded as early ones were welded instead of bolted. Cutting and welding or bolting a new set isn't for the faint of heart, however you have already removed the coach so you are already knee deep.
The earlier torsion axles were also not as standardized as with axles used after 1969. So careful measuring would be needed along with knowing the expected max load the fully assembled trailer with all possible gear and fluids installed. (And I would add 10% to that possibility)
A 2 inch movement is pretty good for a torsion axle. Many don't move that much. And a torsion axle that is close to drawing social security is highly suspect. (very highly) And now would be a far easier time to install an axle rather than when the registration and insurance says it is time to roll. I really don't care what type of spring a vehicle has (leaf, coil, metal or rubber torsion) all springs have a limited service life. I restore several classic cars, after 30 years those metal springs get replaced.
Your call as to the next step. If it were me and having gotten to the place you are at now, spring replacement (axle in the case of a rubber torsion spring) would be my choice. I also tend to not change the design of a vehicle. Again that is just me.
>>>>>>>>>>>Action
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
2001 Bambi belly- corrosion, shocks, disk brakes mswartz 1997 - 2004 Bambi 10 03-07-2008 05:09 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
