Old 09-18-2010, 06:31 PM   #15
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you hook up the 120 v. remember that in the US and Canada we have 60 cycle current, not the 50 cycle that is used elsewhere. What happens to the converter is beyond me. The A/C or any other appliances are all US style. I don't know if you use 120 v. or 240 v. (240 v. would fry the converter and more).
I guess cycles are Hertz now. I guess it made sense to name them after someone who discovered something, but if he's dead now, can't we go back to cycles since they describe it better?
Gene
Old 09-18-2010, 08:28 PM   #16
2005 19' Safari
GLENDALE , AZ
Is this a brand new Airstream or an older vintage model? If it has a new or late model converter in it, it might be easy to change the input voltage. Some newer power supply circuits only require changing cables, jumper wires and/or internal switches to change to "international" voltages/frequencies. Also "Hertz" and "cycles" are used interchangeably in electronics and scientific terms, so no problem...
You should check with the manufacturer or do some research on the Internet before hooking the converter to your household AC voltage supply.
Regarding not using a brake controller or surge braking system, I strongly recommend you have the proper system installed before moving the trailer yourself.
When we were still using our old tow vehicle, I had the brake controller wire pull loose from underneath our pickup, which effectively disconnected the voltage from the brake controller to the trailer brakes. This happened while we were driving in town at around 30 mph. Before I could find a place to stop and check to see why the error message was flashing on the brake controller, a traffic light changed and I was unable to stop and rolled right through a red light. I had sufficient distance to make a normal, gradual stop had the brakes worked. However, without the trailer brakes, I rolled right through the intersection at about 15-20 mph. Luckily, the cross traffic saw what was happening and waited for me to make it through the light. Scary!
So, don't think that driving slow will save you from an accident. Certainly, it will help, but maybe not enough to avoid a crash.
Again, just my opinion (but from previous personal experience)...
Old 09-21-2010, 04:12 PM   #17
Dag68's Avatar
1965 22' Safari
Shelter Island , New York
Images: 20
Why not talk to the seller for advice? If I'm correct you bought this from Rob Baker. He's pretty experienced with airstream renovation and could probably give you some guidance.
Dag68 is offline   Reply With Quote
Texas Beginners 2Rhinos Member Introductions 12 04-25-2010 12:01 AM
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
Brakes mherbert Brakes & Brake Controllers 13 12-13-2006 04:53 PM
brakes rhodyrunwv Brakes & Brake Controllers 7 05-04-2004 06:03 PM
