Old 04-07-2014, 10:26 AM   #1
2007 27' Classic FB
Ridgefield , Washington
Brakes activate on their own
Doing our shakedown for the season. With about five or ten miles to go I noticed that I couldn't maintain speed. Then everything was fine and then it happened again. Thought it was do to some engine problems I've been having. Got to our destination and could smell the brakes. Wheels were hot. (all four of them). Got out and noticed that you could hear the acuator engaging on its own for about fifteen seconds then stopping. This continued even after shutting down the engine. Pulled the lever in the Prodigy and it stopped engaging by itself.
Any ideas? Got about ninety mile drive to get to the dealership.
John & Lisa
Woosch is offline   Reply With Quote
Old 04-07-2014, 10:37 AM   #2
From your description, sounds like the brake controller has a mind of it's own, but all BAD.
Replacing the controller should fix the issue.
Old 04-07-2014, 10:51 AM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Or it could be a bad actuator. What actuator do you have?
Bill
Just my personal opinion
Old 04-07-2014, 11:09 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The first thing I would do is put a volt meter across the output wire of the controller and try to reproduce the effect.
If it happens again and there is no voltage showing on the meter it is in the Actuator. Voltage it is in the Controller.
Depending on the length of time and amount of force the brakes were applying you might consider removing one or two of the brake drums and inspect the spindles and bearings for color and the bearing grease. Heat can cause some problems in that area.
2004 Excursion 4x4
Old 04-07-2014, 04:27 PM   #5
dznf0g's Avatar
Oswego , Illinois
HowieE, I think he has E over H discs. Weren't they standard on Classics in '07?
-Rich-
Old 04-07-2014, 04:32 PM   #6
HowieE's Avatar
Images: 12
Yes from his description I assume he has el/hy.
My comments were to determine where the problem is before just changing out things.
2004 Excursion 4x4
Old 04-07-2014, 05:07 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Check the break away switch too.
It isn't uncommon for the ends of the plastic insert to break or wear away.
Old 04-07-2014, 06:08 PM   #8
2007 27' Classic FB
Actibrake acuator. Hydraulic over electric. Checked the wiring to the breakaway switch and it looked fine. Really out of my league for inspecting brake systems. May need to get someone to come at look at it.
John & Lisa
Old 04-07-2014, 06:20 PM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Was your ActiBrake inspected as a part of the actuator recall? The grey plastic rectangular was the recalled version.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-07-2014, 06:39 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
FWIW if the need arises, through much trial and error I found the Dexter hyd actuator to be the most reliable and durable over the long term.
Old 04-07-2014, 08:32 PM   #11
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Go to Hydraulic mode on controller
Check to see if your controller is in the Hydraulic mode. If it is in the electric drum mode, it will continually cycle on every 15 seconds or so. Set it to Hydraulic mode and see if that helps. (been there, done that)
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 04-08-2014, 09:44 AM   #12
2007 27' Classic FB
Actibrake was inspected. The unit is in hydraulic mode.
Thanks to everyone who has contributed. We REALLY appreciate the input.
John & Lisa
Old 04-08-2014, 10:08 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have seen this on the Actibrake units. The brakes will apply, and sometimes not release until the wires to the actuator are cut.
Since Actibrake is out of business, the fix is to replace the actuator with another brand.
Old 04-08-2014, 10:15 AM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I use and highly recommend the Carlisle 1600 brake actuator.
It has given me 150000 trouble free miles split between my 2 Airstreams.
Who Does Their Own Welding? Roadrunner Repairing/Replacing Floor &/or Frame 56 06-03-2015 09:15 AM
Who here works on their own MH 92landyacht General Motorhome Topics 23 10-28-2012 06:31 PM
Anyone take their own water? THEPILL On The Road... 82 04-08-2010 08:51 PM
Who's done their Airstream with their custom style interior? ANY PICS LAWFISH Upholstery, Blinds, Walls & Interior Finishes 1 02-08-2009 05:36 PM
Airstream starting their own forum? Rog0525 Our Community 10 05-06-2003 09:55 PM
