04-07-2014, 10:26 AM
2007 27' Classic FB
Ridgefield
Brakes activate on their own
Doing our shakedown for the season. With about five or ten miles to go I noticed that I couldn't maintain speed. Then everything was fine and then it happened again. Thought it was do to some engine problems I've been having. Got to our destination and could smell the brakes. Wheels were hot. (all four of them). Got out and noticed that you could hear the acuator engaging on its own for about fifteen seconds then stopping. This continued even after shutting down the engine. Pulled the lever in the Prodigy and it stopped engaging by itself.
Any ideas? Got about ninety mile drive to get to the dealership.
John
04-07-2014, 10:37 AM
Corona
From your description, sounds like the brake controller has a mind of it's own, but all BAD.
Replacing the controller should fix the issue.
04-07-2014, 10:51 AM
1979 23' Safari
1954 29' Liner
Orange
Or it could be a bad actuator. What actuator do you have?
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
04-07-2014, 11:09 AM
Princeton
, New Jersey
The first thing I would do is put a volt meter across the output wire of the controller and try to reproduce the effect.
If it happens again and there is no voltage showing on the meter it is in the Actuator. Voltage it is in the Controller.
Depending on the length of time and amount of force the brakes were applying you might consider removing one or two of the brake drums and inspect the spindles and bearings for color and the bearing grease. Heat can cause some problems in that area.
2004 Excursion 4x4
04-07-2014, 04:27 PM
Oswego
HowieE, I think he has E over H discs. Weren't they standard on Classics in '07?
-Rich-
04-07-2014, 04:32 PM
Princeton
, New Jersey
Yes from his description I assume he has el/hy.
My comments were to determine where the problem is before just changing out things.
2004 Excursion 4x4
04-07-2014, 05:07 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Check the break away switch too.
It isn't uncommon for the ends of the plastic insert to break or wear away.
04-07-2014, 06:08 PM
2007 27' Classic FB
Ridgefield
Actibrake acuator. Hydraulic over electric. Checked the wiring to the breakaway switch and it looked fine. Really out of my league for inspecting brake systems. May need to get someone to come at look at it.
John
04-07-2014, 06:20 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Was your ActiBrake inspected as a part of the actuator recall? The grey plastic rectangular was the recalled version.
04-07-2014, 06:39 PM
1972 31' Sovereign
Benton
, Arkansas
FWIW if the need arises, through much trial and error I found the Dexter hyd actuator to be the most reliable and durable over the long term.
04-07-2014, 08:32 PM
1978 31' Excella 500
Genoa
, Nevada
Go to Hydraulic mode on controller
Check to see if your controller is in the Hydraulic mode. If it is in the electric drum mode, it will continually cycle on every 15 seconds or so. Set it to Hydraulic mode and see if that helps. (been there, done that)
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
04-08-2014, 09:44 AM
2007 27' Classic FB
Ridgefield
Actibrake was inspected. The unit is in hydraulic mode.
Thanks to everyone who has contributed. We REALLY appreciate the input.
John
04-08-2014, 10:08 AM
Retired.
, At Large
I have seen this on the Actibrake units. The brakes will apply, and sometimes not release until the wires to the actuator are cut.
Since Actibrake is out of business, the fix is to replace the actuator with another brand.
04-08-2014, 10:15 AM
Overland Adventurer
2009 34' Panamerica
Telluride
I use and highly recommend the Carlisle 1600 brake actuator.
It has given me 150000 trouble free miles split between my 2 Airstreams.
04-08-2014, 10:22 AM
Retired.
, At Large
Carlisle and Dexter both make good actuators. The Dexter unit is what Airstream uses when they install disc brakes, and is what we use at the dealership when we do an upgrade. The Carlisle is just as good, and costs less, but the Dexter is something dealerships may be more familiar with if you have a problem. Check prices, and decide if the (I think it is a couple hundred dollars) cost difference is worth the POSSIBLE better service if needed.
04-08-2014, 05:50 PM
1972 31' Sovereign
Benton
, Arkansas
Thanks for the heads up in the Carlisle units, I will have to try one next time I need to replace one.
04-08-2014, 10:19 PM
1977 31' Excella 500
West Sacramento
I second the Carlisle.
04-08-2014, 10:22 PM
Genoa
, Nevada
Controller, controller, the thing in your truck
I meant check the controller in your truck, that has to be in the hydraulic mode. The controller can revert to electric drum mode by itself, then the electric drum mode in the controller will activate the hydrulic brake activator every 15 seconds, by it self until you unplug the umbilical. I know because mine does it.
NevadaGeo
04-21-2014, 06:38 PM
2007 27' Classic FB
Ridgefield
Update. The guilty party was the brake controller. After the discussion with this thread we have decided to change the brake actuator soon. Thanks for the help everyone!
John
04-21-2014, 06:55 PM
West Sacramento
I'm sure with either the dexter or Carlisle your problem will be solved.
