Old 12-12-2006, 06:10 PM   #1
Anacortes , Washington
Brakes
What is entailed to switch from surge to electric brakes?
Mike
mherbert is offline   Reply With Quote
Old 12-12-2006, 09:11 PM   #2
Images: 59
1. Take off the coupler. Take off all hydraulic lines. Take off brake drums.
2. Buy new backing plates to match the existing axle flanges.
3. Weld on a new coupler.
4. Run 12V #12 awg power line for breakaway switch.
5. Wire up new 7-way connector to back of tow vehicle.
6. Buy and install electric brake controller
7. Run #12 wire from umbilical to all brake hubs.
8. Purchase and install breakaway switch.
9. Install new electric backing plates and brake drum hubs.
10. Install new bearings and seals.
11. Do initial brake adjustment.
12. Set up and tune brake controller.
I'm sure I missed something.
Old 12-12-2006, 09:43 PM   #3
Brakes
I am obviously a newbie, but this a great forum. Thanks for the help.
Mike
Old 12-13-2006, 06:56 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
What Airstream models came with surge brakes? I understand they like the surge brakes in Europe. Heavy equipment and farm trailers use them here.
Old 12-13-2006, 09:53 AM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I think Mike meant hydrolic brakes! Surge brakes were never used on AS as far as I know. Way too big for the axle setup.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-13-2006, 10:10 AM   #6
We may be talking about the samething. The brakes are actuated hydraulically by a master cylinder at the hitch. I guess one question would be is is this an adequate and safe setup and also, is there a fix whereby the master cylinder can be acutated by a 12v switch from a brake controller?
Old 12-13-2006, 11:02 AM   #7
Images: 59
Mike,
If you wanted to do what you are thinking, do a search on Actibrake. I think Inlandrv even sells a kit that would let you go from surge brakes to electro-hydraulic brakes.
Old 12-13-2006, 11:06 AM   #8
2005 22' Safari
1960 24' Tradewind
Mike-
I think the best thing to do is to change out the whole axle. That's what GSM is doing to our '65 Tradewind. No sweat, no worries!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 12-13-2006, 03:04 PM   #9
1977 31' Sovereign
1989 34' Excella
Herbert,
What you describe is a true surge brake. I do not believe any Airstreams came with them from the factory. Maybe it is not an Airstream or some previous owner did a conversion. What kind or model trailer is it?
The easiest and lowest cost change is to buy the electric backing plates and drums from Kelsy Hayes. You can get them wholesale out of their fractory or thru a distributor for about $340 plus shipping. The drums are heavy. That is for 4 brakes on a double axle trailer.
Old 12-13-2006, 03:21 PM   #10
Somewhere , Indiana
Originally Posted by dwightdi
Herbert,
Hey,
No flames intended but switching from hydraulic disc brakes to electric brakes is one giant step backwards!
I would, also, look into the Actibrake by Kodiak or the E/H actuator manufactured by Dexter axle.
Just two cents from a retired axle dude.
Regards,
Henry
axleman is offline   Reply With Quote
Old 12-13-2006, 03:26 PM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by axleman
Hey,
Regards,
Henry
Henry,
I agree, but we don't know exactly what kind of brakes he has or what age trailer. I remember hearing about hydralic drum brakes on some early trailers.
Bill
Just my personal opinion
Old 12-13-2006, 03:31 PM   #12
Somewhere , Indiana
You're right!
Bill,
Good point!
Perhaps we'll find out more here soon.
Regards,
Henry
Old 12-13-2006, 03:44 PM   #13
Images: 59
Mike,
There are a couple of Dexter distributors in Everett, near you. Dexter Axle - Trailer Axles and Running Gear Components - HOME
They have electric backing plates, hubs, controllers, actuators, everything you need. I have found the local Dexter distributor in Minneapolis to be extremely helpful and will tell you everything you need to do.
Do a search on the Dexter web site for distributors. They also have lots of good information on their website that will answer most of your questions.
As far as an electic switch that can operate the master cylinder on your coupler--we aren't there yet; but someday there will be linear actuators that you can use to directly actuate the master cylinder. Until then, we need to use electric piston pumps like the Actibrake or Dexter DX unit to supply enough pressure.
They are pricey, which is why electric brakes are still popular.
Old 12-13-2006, 04:53 PM   #14
My Airstream is a 1963 22' Safari (double). It is ofcourse a single axle. I bought it from a nice guy who found it in a salvage yard in Rochester, WA. The body is in excellent shape. He removed everything inside, put in new floor insulation, new subfloor, and a pocket door (nicely done) for the head. He also added a grey water tank. So essentially I have a clean slate with which to work. Naturally, I want to have all of the safety gear in good shape before I begin the interior rebuild. There are hydraulic lines to the brake drums.
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
