Old 05-02-2004, 02:10 PM   #1
brakes
Have a 1977 25' Airstream w' brake system involving a complex connection to the towing vehicle and engine vacuum. Is there a way to retrofit either surge brakes or electric control to the system? How do most people solve this problem?
rhodyrunwv is offline   Reply With Quote
Old 05-02-2004, 03:19 PM   #2
1978 31' Excella 500
1948 22' Liner
Costa Mesa , California
Brakes
If you have the Vacume brake system don't change it!!! I sold my tow vehicle with out removing the vacume parts and could not replace them. I had to go to electric brakes this ment changing from disk braks to drum brakes. It is now a constant problem for me. The disk braks are not only very jerky they squeel so loud I have to turn them off around town. If anybody knows a solution I would appreciate it.
Jim Miller is offline   Reply With Quote
Old 05-02-2004, 04:25 PM   #3
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
You may want to check out this previous thread http://www.airforums.com/forum...=8588#post8588
Coastalview is offline   Reply With Quote
Old 05-03-2004, 09:18 AM   #4
Jim Miller.
Which brakes are noisey? The disc or electric?
Old 05-03-2004, 10:23 AM   #5
1948 22' Liner
Brakes
Dear Andy,
The drum brakes are the ones that are noisey, and jerky!! I loved my disk brakes if there was a way to go back I would spend the $$
Old 05-03-2004, 06:38 PM   #6
Jim Miller.
There is a way to go back as well as convert an original electric brake system to hydraulics.
The new system is far simpler than the old.
I am gathering the costs and procedure, but it will take a few more days.
I will post that information, when I have it completed.
Old 05-04-2004, 09:41 AM   #7
1948 22' Liner
Brakes
Thanks Andy,
Please include installation I am not far from your place. I have the 1978, 31' Exella 500 that Barry polished last year.
Old 05-04-2004, 07:03 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Disc brakes
Guys, I love the disc brakes on my '77 Excella 500. I've had the trailer for 3 yrs. and travelled close to 2000 miles with no problems. The vacuum hose arrangement that can be tapped into the engine manifold of a gas engine can be replaced with a Delco vacuum pump as a source and mounted on the tongue.
There is a source of parts that allows you to replace the entire booster system on the tongue of the trailer with a small vacuum pump/hydraulic unit that is connected directly to the hydraulic line of the trailer. I've seen a number of ways to do it. I'd rather do it that way than to go to electric drum brakes which definately are not superior to the disc brakes.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 01:48 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
