Old 10-06-2003, 06:53 AM   #15
Mike76251's Avatar
Originally posted by Chas
Mike,
You mean you originally had the round magnets and went to the ovals, correct? You did do the right thing by replacing the entire assemblies, I did my 74 Overlander this past spring.
BTW, Welcome to the forum!!
Chas
Thanks for the welcome!!!!!!
I would blame old age for that slip-up but I can't yet.....drats.
You are right..........the round jobbers were getting hard to find.
The main reason I started buying magnets (or trying to) in the beginning was that the wires going into the magnet itself kept "melting".
Once the wire corrodes or whatever, a new magnet is the only fix.
Mine should be good for 30 more years......at least they better!!
I might also add to those joining us that it is very important to replace the bolts that hold the brake assembly to the axle.
I went with metal grade-8 lock nuts. Don't ever use nylon lock nuts on these as the heat will melt the nylon.
Mike
Mike76251 is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 08:00 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 12:48 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
