Old 08-14-2012, 06:59 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I stopped by today to take a look at what they were doing. If anything they understated how bad the wiring was. The wires looked even worse than I expected all very brittle and cracked. They were able to get to the interior wires by cutting a couple of 6X9 inch holes in the belly pan and will be riveting pieces back in to cover and seal the holes. Much of the interior wiring that I can see does not look much better. I will be replacing those sections when I swap out the converter and batteries. But that is another project.
MICHAEL
Old 08-14-2012, 08:22 PM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Bad Brake Overview
Brake Wire Feed Upgrade
"Static Test"
slowmover is online now   Reply With Quote
Old 08-15-2012, 05:08 AM   #17
AWCHIEF's Avatar
Images: 33
Interesting reading, thank you,
MICHAEL
Old 08-21-2012, 08:45 PM   #18
AWCHIEF's Avatar
Images: 33
I finally have working brakes & a functional brake away system. It took a while but it is worth it to know that I will have them when needed.
MICHAEL
