Old 03-20-2008, 04:13 PM   #1
azfiredog300's Avatar
Surprise , Arizona
Brake wiring - axle upgrade
I wanted to get your opinions on connecting my brake wires. I just got my new axles and will install them on Saturday, my question is should I stay with using wire nuts to connect or should I solder the wires then cover with shrink wrap?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 03-20-2008, 04:39 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you want the best connection solder them. However to insure access for testing while on the road I wire nut them. You can lightly tin each wire tip before connecting them for additions conductivity. After wire nutting I wrap the connection with electrical tape and position the wirenut in an up right position and tie wrap it to the spindle. I use a large tie wrap around the spindle and then a small wrap to attach the wirenut to the larger wrap. This prevents water from getting to the connection and provides access.
If you wirenut make sure you uses Ideal wirenuts as they can be undone. Brand X wil brake the wires as you attempt to open the connection.
2004 Excursion 4x4
Old 03-20-2008, 04:41 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I used soldered crimps on ours. No problems so far.
Old 03-20-2008, 04:42 PM   #4
HowieE's Avatar
Images: 12
Remembered I had a picture after the post.
2004 Excursion 4x4
Old 03-20-2008, 04:59 PM   #5
It appears from your photo that the brake wiring is too short.
When the torsion arm swings upward, it will pull on the wire and possible rip it apart.
There should be a much larger loop in the wire that will allow the torsion arm to swing to it's maximum.
it also appears that your backing plates are on backwards, with the right being on the left, etc.
But that also depends on who made your backing plates.
Old 03-20-2008, 05:13 PM   #6
HowieE's Avatar
Images: 12
Well Andy those wire have been there for at least 100,000 miles and they are doing just fine. If you study the picture you will see the wire is attached to the swing arm, a factory attachment, and free to flex between the frame grommet and the axle attachment. The total movement in the wire is limited by the original factory design since the have done nothing on the factory side of the arm attachment.
2004 Excursion 4x4
Old 03-20-2008, 05:21 PM   #7
1977 24' Argosy Motorhome
1977 24' Argosy 24
Janesville , Wisconsin
if you do use wirenuts may I suggest you use some weatherproof ones with a gel compound inside to stop corosion, they're available at home depot and other hardware stores
a little insurance for the downhill slopes
-Matt
schaapveld4 is offline   Reply With Quote
Old 03-21-2008, 12:46 AM   #8
Surprise , Arizona
Ah yes, I forgot about the weatherproof ones, I think I'll give that a try then check them when I get to the 4CU resto rally. Then I will make the final decision. Thanks for all your input.
Jerry C.
WBCCI #13317
AIR #25664
Old 03-21-2008, 04:45 AM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Marine connectors are also good for this application. What gauge are brake wires?
Ancor
16 - 14 Adhesive Lined Heat Shrink Butt Connectors
The adhesive built into the sleeve heat shrink tubing of these Ancor Marine Grade heat shrink butt connectors shrinks to form a tight seal and the ultimate in vibration and strain relief
Features:Tinned for corrosion resistance
Pure copper for maximum current flow
Brazed seam for maximum strength
Nylon insulator preferred by experts
Old 03-21-2008, 08:42 AM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Ancor
Good Find! I was looking for these yesterday. Guess I was too tired. Wires that are soldered in a vibration rich enviroment will break just outside the solder joint. This is why the FAA specs Crimp connectors and stranded wire. It will hold up much longer. The Marine grade ones have something the Aircraft grade do not. The little bit of shrink tubing on the end. I like that.
Michelle TAC MT-0
Sarah, Snowball
Old 03-21-2008, 10:51 AM   #11
1988 25' Excella
CUYAHOGA FALLS , Ohio
The PO of my TT did'nt do a good job of wiring the brakes. After I started going over everything, found the LF brake shoes we'nt worn as much as the other three. Pulled the break-away pin and found that that brake's magnet was'nt operating. Cleaned up all four brake's wire ends, installed wire nuts and then painted each one with (3M) liquid tape. This can also be done with crimped connectors. Seals everything real good.
EXCEL88 is offline   Reply With Quote
Old 03-21-2008, 11:35 AM   #12
Surprise , Arizona
Where can I get those marine connectors? I'll try them all if I have to.
Jerry C.
WBCCI #13317
AIR #25664
Old 03-21-2008, 11:39 AM   #13
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Best price I was able to track down.
Amazon.com: Ancor Marine Grade Electrical Nylon Insulated Adhesive Lined Heat Shrink Butt Connectors: Sports & Outdoors
Old 03-21-2008, 11:51 AM   #14
Surprise , Arizona
Thanks Ganglin, always a pleasure hearing from ya. That link was what I needed.
Jerry C.
WBCCI #13317
AIR #25664
Axle upgrade question Tin Diesel Axles 12 12-07-2007 03:36 PM
16' Bambi Axle/tire/brake upgrade ljmiii Axles 2 02-26-2007 04:46 PM
Axle upgrade, single to double William8979 Axles 17 02-13-2005 08:23 AM
Axle upgrade markdoane Axles 12 04-14-2004 06:42 PM
Upgrade your old axle! markdoane Axles 0 11-20-2003 04:23 PM
