Old 03-21-2008, 12:47 PM   #15
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
We've been using these in the auto repair biz for almost 15 years now. I've found them at NAPA when I need one at home. Might be made by 3M. The ones at the shop come out of Germany and work better in that they don't need as much heat to shrink.
Speaking of which, use a heat gun and not an open flame. You don't need to inadvertantly burn the insulation off a wire.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 03-21-2008, 09:55 PM   #16
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by azfiredog300
Where can I get those marine connectors? I'll try them all if I have to.
west marine has them as well. If you are near one you can have them tomorrow.
West Marine: Store Locator
Michelle TAC MT-0
Sarah, Snowball
Old 03-22-2008, 04:48 PM   #17
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Found the 'marine connectors' today at Lowe's - 18 pack - 3 different sizes for 10.00.
Old 03-22-2008, 04:51 PM   #18
Keymar , Maryland
did they have the shrink tube on the ends? Just because they are marine grade does not mean they have the ability to completely seal out moisture.
Michelle TAC MT-0
Sarah, Snowball
Old 03-22-2008, 04:57 PM   #19
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Yes they did - single crimp spot in the middle. The only thing they didn't have was the "adhesive" the Ancor ones mentioned. Still much better than a wire nut and tape don't we think....
Old 03-22-2008, 05:01 PM   #20
Keymar , Maryland
yes
Michelle TAC MT-0
Sarah, Snowball
Old 03-22-2008, 06:53 PM   #21
azfiredog300's Avatar
Surprise , Arizona
Yes indeed, I do like that idea the best. Thanks for finding them, cuz I got a Lowes real close.
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 03-22-2008, 06:57 PM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
ANCOR is superior stuff. I have been using it on cars, etc for about 20-years. A new [4] lamp headlight harness with all ANCOR materials can be expensive by comparison to ordinary automotive grade, but the USCG-rating and general quality has meant I have never had to re-do a harness despite many miles and with a vehicle never garaged.
The one caveat some will bring up is that TXL auto grade has a higher heat resistance. I say, buy a piece of both see what you think.
The WEST MARINE catalog is one I keep in the trailer along with GRAINGER and a bookmark on this machine to McMASTER-CARR, all good sources for small stuff. AIRCRAFT SPRUCE & SUPPLY is a fun one (Just check out Tefzel wiring for your next project [gulp]).
Old 03-22-2008, 07:40 PM   #23
Surprise , Arizona
I just called where my A/S and axles are to get the gauge that the wires are. They told me that all the ends either have male or female connectors on them. Do they just plug in or am I supposed to cut the connectors off? Darn, he never did tell me what gauge they were either.
Jerry C.
WBCCI #13317
AIR #25664
Old 03-22-2008, 09:36 PM   #24
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thought about those also but was not able to find them with the shrink wrap body. They just snap in and out of each other. If you already have those you could always use them and then coat the connections with liquid electric tape (Llowes). Either way will still beat wire nuts and tape in my opinion.
Old 03-22-2008, 10:52 PM   #25
Surprise , Arizona
well, sounds like liquid tape for me. Hey Gary that stainless light cover looks and fits great. Thanks again.
Jerry C.
WBCCI #13317
AIR #25664
Old 03-23-2008, 10:41 AM   #26
Keymar , Maryland
You can also use shrink tubing over the entire connection.
Michelle TAC MT-0
Sarah, Snowball
Old 03-23-2008, 10:58 AM   #27
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had one of my connectors break. Soldered the wires and covered with shrink tubing.
Richard
Old 04-07-2008, 08:38 PM   #28
Surprise , Arizona
Well, the axles are in and the brakes are wired. I just did a quick wire nut on the wires temporarily to get it home. Now comes my dilemma.
When I plug in the pigtail my backup lights on the TV come on. With the TV lights off for day driving I have brake and turn signals but when I turn on the lights for night driving I have tail lights and no turn, when I step on the brake the left light doesn't change and the right light goes out completely. all the wiring in pigtail and at the trailer plug work but something fr4om the triler plug back is amiss. Any ideas?
Jerry C.
WBCCI #13317
AIR #25664
Axle upgrade question Tin Diesel Axles 12 12-07-2007 03:36 PM
16' Bambi Axle/tire/brake upgrade ljmiii Axles 2 02-26-2007 04:46 PM
Axle upgrade, single to double William8979 Axles 17 02-13-2005 08:23 AM
Axle upgrade markdoane Axles 12 04-14-2004 06:42 PM
Upgrade your old axle! markdoane Axles 0 11-20-2003 04:23 PM
