Old 08-19-2015, 08:48 PM   #43
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by cole3444 View Post
Thanks Agent 86 for the site. I had forgot about them. Ordering the terminal blocks and shipping will be between $7 and $8. Big difference. They are now in my saved list.
Sorry,
I hadn't realized that their shipping for small quantities was so much. My parts bills with Waytek usually run several thou per order, so the shipping is no big deal at that level.
Old 09-20-2016, 02:29 PM   #44
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
bumping an old thread, but I was wondering:
10 or 12 gauge for new brake wire? (going to re-do mine; 2 axles).
as for the junction method, any reason not to use something like this to bind all 5 wires to:
https://www.amazon.com/Sierra-Intern...MHV5SWJJNQP16P
Or is the single terminal post (1 for pos, 1 for neg) preferred?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-20-2016, 03:56 PM   #45
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Each brake may draw 3 to 3 1/2 amps.
12 gauge wire should handle up to 20 amps. A 10 gauge is larger wire. I would not go smaller than 12 gauge.
The junction bar you show works well for installations that are not exposed to weather.
>>>>>>>>>>>Action
Old 09-20-2016, 05:54 PM   #46
lewster's Avatar
Your brakes are of extreme importance!!! In calculating potential voltage drop in a DC circuit, the length of the current path consists of both positive and negative circuits, or the wire length times TWO.
I would use a 10 AWG for your brake circuits, using either stranded marine cable or dedicated brake cable. The price of safety is not worth the difference in cost between 12AWG and 10AWG.
Lew Farber
Old 09-21-2016, 07:14 AM   #47
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
You may find this helpful
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 09-21-2016, 07:50 AM   #48
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Thanks...so according to the pdf, 12 would be adequate, but what the heck?
I don't mind going with 10; the cost difference is insignificant. I just wanted to make sure there was no down side with doing that.
Also...the bus bar. would the single post be better, or does it not matter?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-21-2016, 09:18 AM   #49
1958 18' "Footer"
As far as the wiring I would think that Lewster is saying to err on the side of caution. Here is a link to a wiring chart that may also help;
http://assets.bluesea.com/files/reso...on_chartlg.jpg
You may want to check with the manufacturer to confirm what Voltage Drop they say is acceptable. Keep in mind a 10% Voltage Drop would equal about 1.3 Volts DC or so where a 3% Voltage Drop would equal about 3.9 Volts DC using 13 Volts DC as the base.
Steve
Old 09-21-2016, 11:34 AM   #50
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
RV.net has at least one very very good link to re-wiring trailer brakes. See the travel trailer section. ANCOR Wiring is tough to beat. Terminations and junctions of equal quality are covered. With photos.
Hensley Arrow. 9-cpm solo, 15-cpm towing
slowmover is online now   Reply With Quote
Eagle View RV Resort VS Mesa / Apache Junction KOA airstreamski On The Road... 5 04-03-2009 10:50 PM
Stranded in Grand Junction, CO ArtStream Off Topic Forum 20 08-20-2007 10:38 AM
Apache Junction, AZ -- need help tn2 General Motorhome Topics 47 02-01-2007 12:56 PM
Junction, Texas So Llano River SP April 16, 17, 18, 2004 87MH Forum Rallies & Meet Ups 12 04-19-2004 12:41 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
