08-19-2015, 02:32 PM
#41
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Brake wire junction
Thanks Agent 86 for the site. I had forgot about them. Ordering the terminal blocks and shipping will be between $7 and $8. Big difference. They are now in my saved list.
08-19-2015, 08:37 PM
#42
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I but a lot of stuff from Del City.
I like um!
08-19-2015, 08:48 PM
#43
Naples
Sorry,
I hadn't realized that their shipping for small quantities was so much. My parts bills with Waytek usually run several thou per order, so the shipping is no big deal at that level.
lewster
09-20-2016, 02:29 PM
#44
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
bumping an old thread, but I was wondering:
10 or 12 gauge for new brake wire? (going to re-do mine; 2 axles).
as for the junction method, any reason not to use something like this to bind all 5 wires to:
https://www.amazon.com/Sierra-Intern...MHV5SWJJNQP16P
Or is the single terminal post (1 for pos, 1 for neg) preferred?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
09-20-2016, 03:56 PM
#45
Moderator dude
1966 26' Overlander
Phoenix
Each brake may draw 3 to 3 1/2 amps.
12 gauge wire should handle up to 20 amps. A 10 gauge is larger wire. I would not go smaller than 12 gauge.
The junction bar you show works well for installations that are not exposed to weather.
>>>>>>>>>>>Action
09-20-2016, 05:54 PM
#46
Naples
Your brakes are of extreme importance!!! In calculating potential voltage drop in a DC circuit, the length of the current path consists of both positive and negative circuits, or the wire length times TWO.
I would use a 10 AWG for your brake circuits, using either stranded marine cable or dedicated brake cable. The price of safety is not worth the difference in cost between 12AWG and 10AWG.
Lew Farber
lewster
09-21-2016, 07:14 AM
#47
1958 18' "Footer"
Idyllwild
You may find this helpful
09-21-2016, 07:50 AM
#48
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Thanks...so according to the pdf, 12 would be adequate, but what the heck?
I don't mind going with 10; the cost difference is insignificant. I just wanted to make sure there was no down side with doing that.
Also...the bus bar. would the single post be better, or does it not matter?
Air:291
Wbcci: 3752
'73 Safari 23'
09-21-2016, 09:18 AM
#49
1958 18' "Footer"
Idyllwild
As far as the wiring I would think that Lewster is saying to err on the side of caution. Here is a link to a wiring chart that may also help;
http://assets.bluesea.com/files/reso...on_chartlg.jpg
You may want to check with the manufacturer to confirm what Voltage Drop they say is acceptable. Keep in mind a 10% Voltage Drop would equal about 1.3 Volts DC or so where a 3% Voltage Drop would equal about 3.9 Volts DC using 13 Volts DC as the base.
09-21-2016, 11:34 AM
#50
Vintage Kin
Fort Worth
RV.net has at least one very very good link to re-wiring trailer brakes. See the travel trailer section. ANCOR Wiring is tough to beat. Terminations and junctions of equal quality are covered. With photos.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Eagle View RV Resort VS Mesa / Apache Junction KOA
airstreamski |
On The Road... |
5 |
04-03-2009 10:50 PM |
Stranded in Grand Junction, CO
ArtStream |
Off Topic Forum |
20 |
08-20-2007 10:38 AM |
Apache Junction, AZ -- need help
tn2 |
General Motorhome Topics |
47 |
02-01-2007 12:56 PM |
Junction, Texas So Llano River SP April 16, 17, 18, 2004
87MH |
Forum Rallies & Meet Ups |
12 |
04-19-2004 12:41 PM |
Wire ,wire, oh wire can it be ?
69 Silverback |
Electrical - Systems, Generators, Batteries & Solar |
8 |
05-15-2003 11:09 AM |
