Old 08-15-2015, 07:44 AM   #15
1973 25' Tradewind
Augusta , Georgia
I would use a trailer junction box. VTS has a 7-way. eTrailer has a couple of other options/styles. I've installed this on several trailers and often use at work connecting instruments & components to data logging systems when I only have a few wires.
This gives a common point for wires and gives you a place to start when you need to trouble shoot.
DGJackson is offline   Reply With Quote
Old 08-15-2015, 11:35 PM   #16
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
They do not allow more than 3 connections at any one terminal either. The problem isn't that the copper wire gets brittle when heated, more that the stranded wire has a "hard spot" when soldered.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 08-16-2015, 11:36 AM   #17
lewster's Avatar
Naples, FL , Hood River, OR
The ABYC ( American Boat and Yacht Council) that produces the E-11 electrical codes for the marine industry calls for a maximum of 4 wires on a terminal block or binding post, the latter being the device I would probably use in this case.
Each wire is crimped into a heat shrink ring terminal with a second layer if adhesive lined heat shrink over that. Then the 4 ring terminals are bolted on to the binding post. The non-conductive base of the post is then screwed into a hard surface like the frame.
Makes a bomb-proof connection that will outlast your trailer ........ And no solder!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-16-2015, 11:47 AM   #18
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
got a link for such a device?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-16-2015, 09:26 PM   #19
lewster's Avatar
Here ya go: Junction Block Stud Red 1 Stud Thread 5/16-18 250A - 47202
Old 08-16-2015, 10:27 PM   #20
1979 23' Safari
Wayland , New York
Lester, block stud, thanks just what I was looking for, glad you jumped in. I'd think that the extra thickness of the wire end of the crimped on ring would interfere when stacking them on the post, do you simply rotate the wires a little so they don't directly overlap so the ring terminals lie flat? Recommendations on preventing corrosion to the copper wire down in the belly. Thick coat of noox or dielectric grease?
Thanks!
Old 08-16-2015, 10:34 PM   #21
lewster's Avatar
Brake wire junction
Maximum of 4 ring terminals (per ABYC spec. ) per post. You can flip the first up side down with one on top right side up, getting a flat space between the two. Put the next 'pair' slightly rotated to clear the first pair.
I usually spray with Boeshield, Corrosion X or Corrosion Block from NAPA. All work well!!
Oh, BTW, it's leWster....... :-))
Lew Farber
541-490-6357
Old 08-16-2015, 10:44 PM   #22
1979 23' Safari
Wayland , New York
Lew Farber
541-490-6357
Sorry I know it's lewster, lew, stupid spell check changed it on me. See you on here all the time with lots of good info.
Found the below, looks like it would be good for 5 wires, maybe not to ABYC spec but possibly RVIA? At least probably for my trailer. I'll sandwich the supply wire between 2 wires above and below so current isn't trying to go through so many connectors either way.
http://www.amazon.com/gp/aw/d/B005JU...69M2NANAC3CTZZ
Old 08-16-2015, 10:58 PM   #23
lewster's Avatar
That would work as well, but you are fanning out the ring terminals. You can use the one I linked to with more wires if you like, it's just not to ABYC, but then neither is RVIA!!
Old 08-17-2015, 09:38 AM   #24
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I wonder why the factory didn't use this sort of thing in the first place; it looks like it would be not only more secure, but also faster and cheaper than the convoluted system of vampire taps and wire nuts that were used originally.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-17-2015, 10:01 AM   #25
lewster's Avatar
Because it might eat into their profit margin!!!!
Old 08-17-2015, 12:08 PM   #26
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Brake wire junction
Bits and pieces end up being among the most expensive parts of a build.
A few dollars here, a few minutes of install time there.... It all adds up, and quickly.
There is always a balance between cost and real value added.
Thrift does not bother me near as much as things that are designed to break at a specific lifespan.
Old 08-17-2015, 12:17 PM   #27
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Sorry, jumped in late. Junction box with stud terminals sounds like the ideal solution.
But just in case you want to go with solder, you have mentioned fluxing then soldering. That sounds like acid core. Most electronic solder has flux in it and will be adequate for clean wires. Do not use acid flux paste. It will wick up the strands, can't be adequately cleaned and will ultimately cause the connection to fail. If you are going to solder, the basics are: clean wires, good mechanical connection, good solder joint (wire must be hot enough for the solder to plate out), protect from the elements, and provide good mechanical support.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-17-2015, 12:21 PM   #28
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
IMHO a good crimp fitting is every bit as good as a soldered joint and more so.
Eagle View RV Resort VS Mesa / Apache Junction KOA airstreamski On The Road... 5 04-03-2009 11:50 PM
Stranded in Grand Junction, CO ArtStream Off Topic Forum 20 08-20-2007 11:38 AM
Apache Junction, AZ -- need help tn2 General Motorhome Topics 47 02-01-2007 01:56 PM
Junction, Texas So Llano River SP April 16, 17, 18, 2004 87MH Forum Rallies & Meet Ups 12 04-19-2004 01:41 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
