Old 06-28-2011, 03:57 AM   #1
ckbailey97's Avatar
Scio , New York
Brake Shoes - Where to buy?
I have a 1971 Tradewind and it needs shoes. Magnets are good, springs are good, everything else is fine.
Do I have to buy the whole assembly? or is there somewhere I can just buy the shoes? Also - if I DO in fact need to buy the whole assembly, where do I buy replacement shoes for that should I ever need them?
ckbailey97 is offline   Reply With Quote
Old 06-28-2011, 05:12 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You can buy just the shoes but that cost and the time to change them you are better off buying the complete assembly. Probably like $32.00 to $49.00 and 4 bolts and 2 wire nuts compared to a 15 mins. per set of shoes.
2004 Excursion 4x4
Old 06-28-2011, 05:18 AM   #3
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
I agree with HowieE. The difference in cost is minimal and with the new plates you get new springs, new magnets, etc.
mhilley is offline   Reply With Quote
Old 06-28-2011, 05:22 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
To directly answer your question, you can get just new shoes from nearly any RV place or trailer repair shop. Like everybody else here so far, I'd really lean toward replacing the entire 40 year old assemblies.
Old 06-28-2011, 05:46 AM   #5
Kevin245's Avatar
Ditto on replacing the entire backing plate assembly. All new components, not much more cost, and and peace of mind.
Eleanor Roosevelt
Old 06-28-2011, 06:26 AM   #6
Be Calm, Have a Cupcake
Secguru's Avatar
Houston , Texas
I bought new brake shoes at my local RV Parts store, but they told me they were out of brake socks at the time. I was advised that without proper brake socks, the brake feet could get dirty and smelly right away.
What should I do?
Secguru
Would you rather have a mansion full of money or a trailer full of love?
Secguru is offline   Reply With Quote
Old 06-28-2011, 07:47 AM   #7
Your Airstream has 12 inch brakes.
12 inch brake backing plates are mounted with 5 bolts.
10 inch brake backing plates are mounted with 4 bolts.
Old 06-28-2011, 08:17 AM   #8
1975 29' Ambassador
Reno , Nevada
one of the most cost effective places I've found for backing plates is eastern marine -especially if you wait for one of their sales. Standard 12x2 plates run about $40 and include the shoes, magnets, springs -
Old 06-28-2011, 08:28 AM   #9
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
has any one tried self adjusting backing plates, if so is there any problems with them?
krlajwvater is offline   Reply With Quote
Old 06-28-2011, 08:38 AM   #10
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I have had the self adjusting for about 18 months now and about 5,000 miles. I did the backing plates.
No problems.
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 06-28-2011, 08:50 AM   #11
So far, no reported problems, other than they cost a little more.
Old 06-28-2011, 08:55 AM   #12
There are different versions of backing plates.
As an example, 2 of the more popular 12 inch backing plates have different stopping power ratings.
One is 5200 pounds per axle and the other is 6000 pounds per axle.
Extra stopping power can save the day should the tow vehicle brakes fail. It does happen.
Also, keep in mind that all electric brake ratings assume that the brakes are "perfectly" adjusted, and that the shoes are not glazed.
As electric brakes wear, their stopping power decreases.
Old 06-28-2011, 09:15 AM   #13
tinman1's Avatar
2002 30' Classic
East Central , Alabama
I recently purchased complete Dexter 12" x 2" self adjusting brake assemblies from E Trailer.com
Includes back plate, shoes, springs, magnets complete assembly -
Also bought new drums as the drums were worn where the magnets had deeply scoured the armature portion of the drums. They came complete with bearings and seals.
Gives a feeling of comfort knowing all is new.
Curt
tinman1 is offline   Reply With Quote
Old 06-28-2011, 09:55 AM   #14
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Went the self adjusting route on our '85 Excella. No problems and all seems to be working just fine. Did the complete assembly since I didn't have a history on the maintenance. Easy job. The nuts for the backing plates are a bear to reach. Get a set of ratcheting box wrenches at Sears. You'll be glad you did. But the job is easy and straightforward.
Go for it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Brake controller incompatibility? Flying Gypsies Brakes & Brake Controllers 7 10-31-2011 12:41 PM
2000 airstream excella-hail damage--best buy on ebay eBay Watch Airstreams on eBay 0 04-27-2011 06:50 PM
Where do you keep your shoes? J5MM Full-Timing 14 04-08-2011 09:21 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
