Old 08-17-2011, 02:13 PM   #1
DFDureiko's Avatar
2004 34' Classic S/O
Brooksville , Florida
Brake shoes
Iffy of mine is doing the brakes and bearings on my 04 classic limited slide
Airstream is telling me the shoes are special order? Arent they generic 12pm electric brakes????
DFDureiko is offline   Reply With Quote
Old 08-17-2011, 02:59 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
There should not be any problem getting shoes for electric brakes.
The however, in this is usually the magnets wear out before the shoes and all individual parts are overly expensive .
The entire backing plate assembly including shoes magnets etc can usually be found for $ 50. or less ( Try eastern marine) and everything is new which is why most shops go this route.
The magnets or shoes would likely cost nearly as much as the whole assembly. If you needed both they would exceed the cost.
As far as i have seen the shoes are pretty much generic. I.E Dexter will fit on Hayes etc.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-17-2011, 06:26 PM   #3
TnVolGuy
trmiller's Avatar
1983 31' Excella
Cordova , Tennessee
Send a message via Skype™ to trmiller
I just went through this. I replaced everything on my 83 31' Excella. Mine were what the dealer call 12" x 2. I still had the original round magnets which were actually still in fair shape. The new back plates come ready to bolt on after getting the old ones off. 5 bolts each wheel. If the bearings look good. Clean and repack. Remember the wheel seal on the rear bearing and connectors to hook back up the wires to the magnets. Each wheel took me about 2 1/2 hours but I'm old and slow. Nice thing about this trailer is just pull up on about 3 2x6's and one tire will hang in the air. No jack needed Sum up. Cheaper to go ahead and get the new backers just easier.
trmiller is offline   Reply With Quote
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake Shoes - Where to buy? ckbailey97 Brakes & Brake Controllers 23 09-21-2011 01:43 PM
Brake Shoes, 2004 Limited DFDureiko Brakes & Brake Controllers 2 08-10-2011 05:33 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
