Old 10-27-2010, 12:00 PM   #1
Carson City , Nevada
Brake seizure
Towing my '78 Argosy to storage yesterday I had a brake seize on one wheel and lost the tire amidst a cloud of smoke. The trailer is in storage now, but what a PITA!
Question - What is the likely cause? Can I get a replacement brake drum, shoes, etc (a complete brake system) for one wheel? How much is involved in replacing this?
The hubs and brakes were serviced in September. Should I be concerned about wheel bearing damage?
Any help appreciated.
Mike S is offline   Reply With Quote
Old 10-27-2010, 12:05 PM   #2
The beginning point is to remove the hub and drum, and visually inspect the drum, the bearings, the magnet and the magnet arm. The pin on the magnet arm can come loose, which would cause the problem, as an example.
Old 10-27-2010, 12:11 PM   #3
1986 31' Sovereign
Miami , Florida
Call Andy. Last year I bought 4 full brake sets from him -- came with the shoes mounted on the backing plates and new hardware. Not all that expensive. You may need a new drum as well -- have the old one checked, they may be able to turn it (simpler, cheaper)
I hate to say it but I would do the opposite brake as well -- only way to be sure that the braking effort is fairly even on that axle.
Since you'll have it all apart anyway, pull the bearings, clean and inspect.
Not fun, but fairly simple work (if I can do it, it must be...)
mike
Old 10-29-2010, 11:38 AM   #4
Thanks, Andy and Mike. I'll get after it next week. Does the '78 Argosy have 10" or 12" brakes -- I have not disassembled it yet, and it is in storage at another location. Thanks again.
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
need brake help crowbar68 Brakes & Brake Controllers 12 06-24-2008 08:51 PM
I need a brake Over59 Repairing/Replacing Floor &/or Frame 7 12-07-2004 04:00 PM
Brake Seizure - Front Right Side josephhh Mechanics Corner - Engines, Transmission & More... 15 03-26-2004 10:15 AM
6V Brake ? Deluxe21 Brakes & Brake Controllers 8 08-25-2003 02:42 PM
