Old 01-30-2012, 10:32 AM   #1
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Brake Resistor???
Once again I have been trying to get my brake setup "just right" This time I read the Airstream owners manual for our 1997 34'. In addition to the brake controller (Factory Ford Unit 2009), the manual references a Brake Resistor. I know those were used with the older systems in the 60's, but do I have one on my '97? If so, where would I find it? It is referenced in the manual under the discussion of sequencing the brakes, and says I should start at the mid position and adjust from there for less resistance and greater voltage.
I tried a forum search, but couldn't find anything referencing a newer trailer such as ours.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-30-2012, 11:35 AM   #2
1974 Argosy 20
Kooskia , Idaho
I can't imagine why the manual on a '97 would talk about a brake resistor unless they were just doing a "cut and paste" from a much older manual.
As I recall, from the dim memories of the past, the early brake controllers were sometimes factory set for a 4 brake system, and if used on a two brake single axle trailer you needed a brake resistor to cut the current down. Also, if your really old trailer had 6 volt brakes and you had a newer (at the time) 12 volt system you used a resistor.
But all modern brake controllers that I am familiar with do all the work electronically and have enough range built into their adjustments to compensate for any combination of single to tri axel setups.
Bottom line: I would not worry about it. Just get a good modern brake controller, set it up by the directions provided by the brake controller manufacturer, and you will be good to go.
Old 01-30-2012, 11:47 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
+1
Any 1997 era or later braking system does not need a resistor.
Old 01-30-2012, 11:56 AM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thanks all. Andy even sent a PM explaining it. I believe Airstream simply did a cut and paste, or in 1997 there were a lot of Airstreamers out there with older TV's!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 01-30-2012, 12:32 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I don't think any of the newer controllers would need a resistor. Usually they were used to prevent brake lock up problems with the older hydraulic controllers. i have several resistors I have picked up at flea markets but the only time I have used one is with an old horse trailer with 6 volt brakes and then I installed it permanently on the trailer
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-30-2012, 12:35 PM   #6
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
I have a '97 25' Safari and use a Prodigy Electronic Brake Control. It is advertised for 2,4,6 and 8 brake applications. You set the power knob as instructed, test its sensitivity and adjust accordingly. It also has a "boost" button that allows for a more aggressive settings. Works like a charm.
dirigible25 is offline   Reply With Quote
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
