Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-02-2008, 05:12 PM   #1
watt1968
watt1968's Avatar
Profile:  1968 30' Sovereign
Pelzer , South Carolina
brake replacement parts
Does anyone out there know how to determine the manufactor of the electric brakes on my camper? I have a 1968 Sovereign with what appears to be the original brakes. The drums are 12 in diameter, shoes are 2 in wide, and the backer plates have 5 mounting bolts. I appreciate any feedback.
watt1968 is offline   Reply With Quote
Old 07-02-2008, 05:40 PM   #2
Dan4odm
Commercial Vendor
Dan4odm's Avatar
Profile:  Currently Looking...
Colfax , North Carolina
Brakes
When you take the drums off Dexter has two springs at the top.
Click here to see the Dexter. Then click on one of the lower pictures
If you have K. Hayes, then there is one only one spring.
Dan
Dan4odm is offline   Reply With Quote
Old 07-02-2008, 06:32 PM   #3
watt1968
watt1968's Avatar
Thanks for the help!
Dan,
Thanks for the help! I have Hayes brakes. I don't know if that's good or bad, but at least I know. Again, thanks.
Randy
Old 07-02-2008, 06:42 PM   #4
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I have had Hayes brakes and would not recommend them for this reason. The single spring does not center the brakes shoes as well as the double springs do. This has a tendency to leave the forward shoe in contact with the drum after the brakes are released resulting in a HOT SHOE.
You may not feel this but if you have an exhaust gage on your diesel you will see it in the exhaust temperature.
Complete new backer plates and assembles are to cheap to run the risk.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-03-2008, 05:27 AM   #5
Dan4odm
Commercial Vendor
Dan4odm's Avatar
Did you change yours
Howie
Did you change yours?
We have the best prices on shipping. If we can ship your parts a cheaper way, we do so and pass the savings back to you.
Old 07-03-2008, 08:17 AM   #6
HowieE
HowieE's Avatar
Images: 11
Originally Posted by Dan4odm View Post
Howie
Many times.
Over the years as magnets or shoes wear out I have just replaced the assembly. The last set of axles I got came with Chinese parts and the magnets caused some problems so that set went last spring.
It takes less time to change te backer plates than to change a set of shoes and only cost a bit more.
source/size for brake parts jasper2222 Brakes & Brake Controllers 1 01-28-2008 05:28 PM
Anyone want these brake parts? DavidsonOverlander Brakes & Brake Controllers 1 09-18-2005 07:28 PM
Brake Parts sstjacque Brakes & Brake Controllers 2 09-10-2005 11:41 PM
brake parts Jay & Sue Brakes & Brake Controllers 8 05-14-2004 10:50 PM
Source for brake parts? 74Tradewind Brakes & Brake Controllers 9 06-11-2002 05:26 PM
